Rain sensor troubles
Old May 7, 2009 | 07:23 AM
crackerjack's Avatar
crackerjack
need help.. my car was in the shop and the garage had to remove my front windshield and now my rain sensor does not seem to be working, any thoughts
Old May 8, 2009 | 05:59 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
1st, make sure it is plugged in. There is a wire coming out from the headliner that plugs in to the box behind the mirror.
There is a special adhesive pad that must be used to hold the sensor to the window. When I had my windshield replaced, we tried just using translucent tape, and it didn't work. Then my window guy went back and found the part number for a "rain sensor pad".
Old May 8, 2009 | 12:20 PM
crackerjack
youre spot on cube! the wires were cut, i purchased the connector from the dealership, but do not know how to wire it up. i got the connector with 3 seperate wires. the tricky part is that the connector can accomodate 4 wires, therfore, i do not know which connector hole to leave empty. also, i do not know which wire (from the headliner) goes where in the connector (slot 1, 2, 3, or 4). ill try to look for the pins in the sensor to see if they start far left or far right, and then ill switch around
Old May 9, 2009 | 06:36 AM
crackerjack
hello again, i removed the rain sensor and there are 4 pins in the connector socket. if anyone has a couple of minutes, can you please remove the rain sensor cover and take a pic of the wires going into the connector of the rain sensor while it is connected and when it is not...this would be greatly appreciated
Old May 10, 2009 | 07:20 AM
crackerjack
anybody??
lweaver
Sep 17, 2024 08:22 AM
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
CRC
Dec 26, 2015 11:30 AM
sempaipaul
Sep 18, 2015 03:05 PM
