Squeaky Steering Wheel/Column
Old May 12, 2009 | 03:41 PM
MiniS AZ's Avatar
MiniS AZ
Okay Techies.
My steering column is squeeking consistently. Has anyone else had this problem. Is is fixable?
Old Jun 4, 2009 | 02:45 AM
Jephen19's Avatar
Jephen19
I was about to post the same thing but decided to run a search first. I have the same problem I think.
Here's the deal. When I rotate the steering wheel it will make a low bass sounding squeak from a complete neutral position (when tires are perfectly straight). From this position, turning 5-10 degrees left or right will make this sound. But only when passing this position. Usually only happens when the car is cold or just started. After some time it goes away. But I think it is happening more frequently during start ups. Not only does it make an audible sound, you can feel the squeakiness through the wheel with you hands. It's not a vibration that is too serious, just not normal when compared to when it wasn't there.
Is this similar you what you are talking about? If so I'm in the same boat and don't know what to do about it.
Old Jun 4, 2009 | 03:00 AM
Jephen19's Avatar
Jephen19
I'm going to try this after finals week is over. Hope this helps as this is exactly what I was describing.
https://www.northamericanmotoring.co...-creeking.html
Jim Ferrell
Oct 6, 2015 08:09 AM
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
vetsvette
Oct 1, 2015 12:59 PM
little egg
Oct 1, 2015 12:26 PM
