HID headlight out, and solution
My 04 S was working fine until I noticed that the right Xenon was blinking and then when out. I shut it off and then on and it came on and then off again. The next morning I began shopping for OEM and aftermarket solutions. At lunch I went down to try to determine whether it was a bulb or ballast. I unclipped the bulb and then noticed that "someone" didn't turn and click the bulb into the socket. I carefully tried to separate the bulb from the socket. It finally did and then I saw the problem. By not fully seating the connection, there was arcing across the connections, and how it worked, I won't guess. Well, I was careful not to touch the bulb and ground away the melted plastic and cleaned the contact. Canned aired the bulb and reinserted, and it works perfectly. I don't think the bulb was even inserted correctly. From what I read, others may have thought it was a toasted bulb or ballast. If it happens to you, check the connections and fit first.
Mine ended up being the bulb (was cracked) -
159.99 each for 'factory' Phillips - 103.49 each for brand-x at Advance (nada at Autozone) - 34.99 for pair on eBay (+ free s/h)...
Guess what I'm sporting now
(plus a spare - the used one - in the glove box)...
molala
Oct 2, 2015 01:53 PM
