Does a low mileage MINI need special care
Old May 5, 2009 | 06:45 PM
cadfael_tex's Avatar
cadfael_tex
Overall, my 2005 MCSCa has a little under average mileage for its age (just shy of 33k). However, my mileage now is going to be minimal. Except for maybe 3-4 days a month, I don't drive over ten miles (2 miles back and forth to work and coming home for lunch). I talked with somebody that bikes in and I'm considering it. That means even fewer miles.
The long and short is: is there anything I can do to help maintenance wise when I have such short trips driving every day?
Hope this makes sense, it does in my mind but that's a scary place
Old May 5, 2009 | 09:38 PM
markjenn's Avatar
markjenn
I have an '04 with about 30K, so I'm well below average too. (I try to walk, bike, or motocycle whenever I can.) So far, it has resulted in my driving a 5-yo car that is still in great shape and has required very little maintenance. But... the downside is that depreciation and age-based deteoriation marches on regardless of mileage, so the per-mile cost goes up.
If the car is seeing regular use (driven at least a few times a month), I don't think you're likely to have any issues. I would try and drive the car long enough every week or two to have the coolant and oil temps completely up. And you should do all the calendar-based maintenance - oil/filter at least once/year, brake fluid every couple years, and coolant every four.
- Mark
Old May 6, 2009 | 06:09 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
All good advice from markjenn.
I would look at low mileage more positively. When resale time comes, low mileage cars are more desirable.
Old May 6, 2009 | 08:19 PM
azn_btrfly's Avatar
azn_btrfly
I am in the same boat. My '06 only has 16K on it since my work is only a little over a mile away and I'm too lazy to bike or walk to work.
The last time I brought my car in for an oil change, I asked the tech if I should be worried about all the short trips my baby makes. The only thing he recommended was that I get a battery trickle charger since the short trips do not allow the battery to fully charge and is slowly getting drained over time.
Old May 7, 2009 | 07:00 AM
Suzanne's Chili Red S's Avatar
Excellent advice! Ours is also low mileage (18K) and we use a Battery Tender which does a great job.
Old May 7, 2009 | 07:15 AM
kazlot's Avatar
kazlot
Does a low mileage Mini need special care
As 'markjenn' has posted do all the annual services but also you really may want to think about 6 month oil changes.
The Dealer does the free annual and you, or the shop of your choice, do one six months later.
That's what I do. I do it on my current JCW and I did it on my previous MCS.
For me it usually works out to be as little as 3 thousand miles or as much as 6 thousand miles.
Many years ago I had to have an engine rebuilt long before necessary due to lack of, or infrequent, oil changes.
Yes I know oil and filters are better now but I would rather be safe than sorry.
Just something to think about.
Hope this helps...
bigramdizzle
Aug 6, 2019 09:19 PM
Dec 23, 2015 10:36 AM
Accessory Products
Aug 10, 2015 01:35 PM
Aug 10, 2015 01:33 PM
