PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. New sound...
  2. MCS Exhaust heat shield question
  3. Broken Paddle shifter
  4. power
  5. Kudos to the 6th gear'ers
  6. 1st gear Thunk
  7. Midlands Transmission Fails to Engage Reverse
  8. Break-in period for new tranny/clutch?
  9. CVT Lurching problem reduced with new spark plug wires
  10. Belt Tensioner Tool???
  11. How much did you pay for a %15 pulley?
  12. Warranty Work - Must Dealer Replicate Problem?
  13. Does your MINI shudder?
  14. car doesn't roll!
  15. Removing intake manifold?
  16. engine
  17. Fuse for Seat Warmers?
  18. changing the oil - MCSa '06
  19. Spark Plug jumped out of Cylinder Head
  20. Warranty Acceleration
  21. Spark Plug Ejection Button
  22. Another Warranty Question
  23. My MINI won't start...sometimes
  24. Issue with Gray Leatherette - Flaking color
  25. Am I headed for catastrophic drivetrain failure?
  26. HELP ASAP! Car's acting up...
  27. Change oil too often?
  28. where do I find TIS Bulletins?
  29. alignment issues
  30. Blown Engine!
  31. silicone intercooler boots
  32. stress crack???
  33. 05 ECU wanted
  34. Great place for oil changes in Tampa
  35. cracked upper strut mounts...
  36. AutoEnginuity - Enhanced BMW/MINI Interface
  37. Supercharger R&R
  38. Whoops! Left the sunroof open on my 02 mini
  39. Which spark plugs
  40. Alta Radiator Hoses (where do they go?)
  41. I think I lost my burble!!!
  42. Coolant Capacity
  43. Transmission rattle?
  44. Lower steering column shaft bound up
  45. Tire Pressure Help
  46. MCSa harsh downshift
  47. My car is getting louder and louder!!!
  48. Alta Intercooler Air Diverter Opinions...
  49. Top Brake/Tailight WONT TURN OFF!!
  50. Unexpected Engine Shut Off
  51. is the clutch a warranty item?
  52. Brake Caliper noise
  53. 2 Pre-Cat Bungs
  54. Hmmm... loose or broken engine mount?
  55. Window won't roll down
  56. MINI Rear Quarter Panel Construction: Dent removal
  57. Subtle build differences on '06
  58. Seat Feels Like it Slips Forward
  59. Undercarriage photo
  60. MCSa Reverse problem
  61. Help with my key?
  62. Help with a battery for an MC 2002
  63. Odd exhaust smoke
  64. Pre-Cat o2 sensor with PLX
  65. clutch rattle while in neutral with peddle released
  66. Fan motor screeching
  67. Sunroof
  68. SES light on and clock says EP. Please help!
  69. How to replace rear sidelight bulb?
  70. Weird Check Engine Light?
  71. It's about time for a new Cracked Windshield thread
  72. brake pad recommendations
  73. Mushroomed?.....please raise your hand.
  74. Engine stalling when driving slow/stopping.
  75. Rear Window Washer Fluid Leaking?
  76. OBD2 Drive Cycle Parameters
  77. Rattle : Supercharger / water pump
  78. steering to the right
  79. m7 Strut Brace Install Question
  80. mod parties in the DC/MD area?
  81. Clunk when I shift
  82. 2006 MCS - Slight Hesitation at 3000 RPM
  83. Oil Trap
  84. Headlight Power Washer Problems
  85. Sluggish S, post O2 sensor lean (p2096)
  86. Need help with pinging? I may have found the answer!
  87. A/C question.
  88. Warranty Hell ... not really.
  89. Rough Idle on start - Engine Quits - Battery or Hot Weather Damage?
  90. Hot Mini
  91. Ping heard in hot weather
  92. Power Loss on Dips (?)
  93. How to? Strut mount replacement
  94. What brand of struts are on the MINIs?
  95. Has this happened to your MINI before?
  96. Rumble/grinding sound in engine compartment
  97. Clutch 'Chatter"
  98. Strange clunking sound
  99. blew a hole in my engine!
  100. Our Mini Seems To Have Hydrolocked!
  101. Brown coolant?
  102. Which Optima's will fit a MCS?
  103. clutch squeal
  104. Push Button Start
  105. DSC and ASC
  106. odd noise?!?
  107. 02 cooper engine light.
  108. The Great Power Steering Pump Failure/Problems Thread
  109. Throttle body anyone?
  110. Los Angeles - Transmission help
  111. Car wasn't starting at first.. and then..
  112. Best Mechanic and install Thread
  113. Mini Window Problem
  114. ABS, DSC lights ???
  115. battery dimensions for the mcs
  116. Noise From A/c Fan
  117. Noise From A/C Fan
  118. Hot Disk Brake Problem
  119. Full Throttle Shut-down!!!
  120. Another Xenon Question
  121. Need a belt
  122. A/C Drain tube?
  123. 06 Rumbling
  124. Octane additives - anyone in CA using some?
  125. SES / DSC - Limp Home - on a Manual
  126. plug wires and maint. intervales
  127. question about Inspection II
  128. strange clunking noises
  129. How Many Filters....
  130. Oil Consumption
  131. '05 MCS A/C noises normal?
  132. Air conditioning question
  133. bad stuff happening to my mini please help
  134. Fuel System Questions
  135. Dinan Strut Tower Bar
  136. What kind of Transmission fluid??
  137. Have you had this problem? Limp Mode / Bypass Valve
  138. WOLO "Bad Boy" horn install?
  139. Spontaneous engine bay fires!
  140. Split Strut Mount @ 5600 Miles
  141. Sunroof suddenly squeaky
  142. Average Speed Calculator is wrong
  143. Belt tension...how to lock
  144. Engine Oil loss...
  145. Out of warranty oil change - Tampa area
  146. Sparkplug Tubes
  147. What the heck... MINI won't start.
  148. colored strips on intercooler?
  149. under bonnet insalation-sound proofing
  150. mcs hood scoop
  151. LAG or what?
  152. Air Conditioning At Start Up
  153. How do you know when your struts are bad?
  154. Intermittent Clutch pedal stuck to floor
  155. Dead battery or something else?
  156. 2 Questions, 1 with steptronic, 1 reg auto wipers
  157. i cant get out of my MINI!
  158. shift knob removal
  159. OBD Connector Location
  160. Performance hot vs cold
  161. speedbleeder sizes
  162. Stumbling at speed under low load
  163. Redline MTL or MT90 for trans
  164. Optima Tuning High Performance Module
  165. Squeaking
  166. Power Loss (for the second time)
  167. powertrain trouble?!
  168. Diesel or a Mini?
  169. service engine light
  170. Pulley Puller...
  171. Help....clanking noise
  172. First oil change confusion
  173. Am I missing something?
  174. Need help installing Crank and SC Pulley...
  175. AC compressor fuse where?
  176. EMERGZENCY - Did I just do something REAL stupid?
  177. Oil pressure after oil change
  178. grabby clutch?
  179. What could be involved in a bad shifter bushing?
  180. boost is wierd
  181. Pulley install in Nashville?
  182. cylinder head porting guide
  183. Knocking noise
  184. Max boost readings in Hg
  185. Involuntary "software" reset
  186. Calling those w/scan tools
  187. map sensor plug 03 cooper S
  188. Can the 'burble' be buried?
  189. MCSa over revving...
  190. Cooling Fan Constantly On
  191. MCS vs MC - Does one have more issues than the other??
  192. Electrical Hiccups? Please help...
  193. Question about the MCS Supercharger
  194. JCW intake install help needed
  195. Question about clutch
  196. Greasy film in coolant reservoir!?
  197. Quick 60k service Q:
  198. oil catch can?
  199. Weird noise
  200. Coolant change problem
  201. Diagnostic/reset tools and my problem??
  202. What is a used supercharger worth?
  203. 18-19 miles per gallon with easy driving
  204. Something moving inside my passenger seat
  205. Change my oil before my first service?
  206. Torque Setting Garage Quick Reference
  207. Hood scoop removal instructions
  208. Dilectric grease
  209. Hot weather here..So are my
  210. Anyone else with no AC in an 05?
  211. Warranty Fixes on 03 MCS!
  212. Pitman arm removal tool for SC Pulley
  213. OEM parts
  214. Exhaust port size
  215. Transmissions troubles....help
  216. Wierd brake bleeding experience
  217. Wierd brake bleeding experience
  218. Brakes
  219. So, whats Next? help me decide.
  220. Different Windshield Issue
  221. Pinhole leak at top left corner of radiator (facing car)
  222. replacing the cabin filter.....help please
  223. Powersteering Fan!
  224. alta panel filter fit
  225. Starter Heat Shield Orientation? NEED PIC!
  226. Seat belt warning chime
  227. "Sevice engine soon" High and fluctuating RPM's at idle.
  228. Electric Insulators?
  229. No power to the OBC or Starter... Can't even jump the car!
  230. Removing I/C
  231. flat tire light
  232. Removing Air Cleaner
  233. When parked, car revs up, shakes, and EML/Service Eng Soon Lights come on
  234. Fixing the air conditioning/Insurance Insanity
  235. Xenons going out, every now and then
  236. Smoke on startup
  237. Best replacment air filter
  238. Rain sensing wiper sensitivity.
  239. More engine idle questions
  240. HELP! Both windows are stuck!
  241. p1238, p1242
  242. Buzz from engine bay - need help
  243. Rear A-Pillar!!
  244. Window not working properly
  245. Remapping question
  246. Hatch stuck close.....help
  247. tapping/ticking in neutral at idle
  248. Gas tank clean up!!!
  249. Best Place to order OEM parts?
  250. '06 SIRIUS Antenna...Removal of OEM...S.O.S.
