What brand of struts are on the MINIs?
And McPherson isn't a brand, it's a descriptive term.
Suspension: Steering angle sensor, front coil/leaf springs, MacPherson struts (includes upper mount and pivot bearing assembly),....
The upper strut mount is cracking and my extended warranty states "MacPherson" which I thought was a name brand, not a general description of all struts.
I'm just trying to get my facts/info straight and up to speed so when I take her in on Thursday I am able to fire back if they say they will not cover the repair.
Are you citing from a list of covered items?
I hear what you are saying, it's a slim chance but it's right there in black and white so I will fight if they say no. The coverage I have and what I signed only states what is covered and what is not, nothing in there about something that is about to break vr fully broken. Also, it states that if something breaks and causes damage to something else as a result, that something else is also covered. For example; if the strut mount fully broke and damaged the sheet metal (mushroom) as a result, the sheet metal would be covered as well, again, it's as spelled out as plain as day in black and white.
As I see it, I've put 1k miles on the car and have only owned it for 2 months and their "certified inspections" to make sure everything is at factory specs failed as this was not caught. This is just more ammo for me to shoot if need be.
This is kinda weird!I got home last night to discover the right front shock is leaking from the top and ruuning fluid on the ground!I called the appointment lady,told her the story,she said the mechanics told her shocks don't leak at 24,000 miles,they will have to look at it first.I am going to call back and talk to the REAL service dept,and ask them if they are going to change both of them,and if they even have them in stock!Do you think they will give me some crap about having front and rear strut bars with a 22mm rear sway bar?
Originally Posted by leapfrog
This is kinda weird!I got home last night to discover the right front shock is leaking from the top and ruuning fluid on the ground!I called the appointment lady,told her the story,she said the mechanics told her shocks don't leak at 24,000 miles,they will have to look at it first.I am going to call back and talk to the REAL service dept,and ask them if they are going to change both of them,and if they even have them in stock!Do you think they will give me some crap about having front and rear strut bars with a 22mm rear sway bar? [Emphasis added.]
Don't be surprised if they decline to replace a part that hasn't failed (your other strut).
The Dealer replaced only the blown shock,which they say it's the first time they have ever seen that happen.And,they didn't comment on the rear strut bar,the 22mm rear sway bar,or even noticed the scratched paint where I removed the front strut bar!
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
