Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
There should be a pull loop underneath the rear bench seat. (I'm pretty sure that the pull was on all MINIs...)
-Paul!
Unfortunately, the pull loop was not on all '02 MINIs.
Better have a talk with your local dealer. I believe the pull loop can be added after the fact which will help if this happens again.
Thanks for all the help. No pull loop, but, I pulled the plastic interior panel off and found that messing with the latch will unlatch manually. Problem fixed....thanks guys.
