OBD2 Drive Cycle Parameters
Old Jul 26, 2006 | 02:14 PM
Roadsailer's Avatar
Roadsailer
Please, Please will someone tell me what the "drive cycle" parameters are for a Mini Cooper (2002 Cdn Launch Edn) after clearing a fault light? I have an Innova 3030 code reader and would like to use it as a preventative maintenance tool, but need to know how the car should be driven to cover all of the measured criteria.
Paul
Old Jul 26, 2006 | 04:06 PM
Grassroots Garage's Avatar
Grassroots Garage
Paul,
-start engine, idle cold~2 min. 10 sec. -Evap leak detection is evaluated
-accelerate to 20-30 MPH. Maintain steady speed for 3 min.15 sec. - Establish closed loop operation- o2 sensor responce timeand switching time is monitored
-accelerate to 40-60 MPH, maintain steady speed for 15 min. - catalytic converter efficiency is evaluated.
-come to stop, idle for 5 min. - tank leakage is evaluated.
Don't expect to be able to accomplish all of this in 1 trip. I hope this helps
--Dan
Old Jul 31, 2006 | 07:27 AM
Roadsailer's Avatar
Roadsailer
Thanks so much .... now we're cookin'
Paul
Old Jul 16, 2020 | 12:16 PM
bowmankelley's Avatar
bowmankelley
Does anybody know whether you can read readiness state with a Carly Adapter and App? Also, Once you have passed one check is it necessary to do all of the steps that Grassroots Garage mentioned or can they be done over time. In other words will a pass stick in the Memory? If you idle in the car to check evap leak detection and you pass, does the module save this info so you only have to clear the other 3 checks?
Old Aug 24, 2020 | 10:52 PM
Dinan53's Avatar
Dinan53
Monitors and Car Memory
Bowmankelley:
Did you get an answer to your question for Grassroots Garage? The one about the car's computer remembering that monitors have passed? And whether you need to clear all four in one trip or if you can get them to pass over several trips?
Grassroots Garage looks to have been banned. Did you get an answer or find out somewhere else?
Thanks in advance.
Dinan53
gonch69
Mar 3, 2016 12:58 PM
Ensign
May 28, 2015 01:43 PM
trinity5614
Jan 22, 2014 04:13 PM
Mjimport
Oct 25, 2013 04:09 PM
golden_child
Jul 17, 2012 02:41 PM
