Mini Window Problem
Old Jul 19, 2006 | 01:17 PM
ddebiz's Avatar
ddebiz
Mini Window Problem
Hello,
I'm new to this forum. I just picked up a 2003 Mini S with 20K mile, and the driver's window doesn't even try to open. The switch seems connected because I can see a slight dim in the interior light when trying. The fuse is fine I even replaced it in hopes that was the only problem. Per another thread on the NAM this seems to be a problem. Can any one tell me what the new motor is going to run and can a regular BMW dealer put it in? The 3 year warrenty is over due to the Nov 2002 original delivery date.
Old Jul 19, 2006 | 02:25 PM
Chimera's Avatar
Chimera
MINIs come with 4 year, 50,000 mile warranties....so you should still be covered if Nov 2002 was the delivery date.
Old Jul 19, 2006 | 04:21 PM
T2Nav's Avatar
T2Nav
Does it move down & up a quarter inch when you open and close the door?
Old Jul 19, 2006 | 05:20 PM
jfhaia's Avatar
jfhaia
Mini Window Problem
I have a 2004 and experianced the same problem, twice! Stopped by Mini of the Main Line to complain. The Service Manager said it is a common problem. Contacts on the motor corrode and the motor armature sticks (or something like that). The service manager said to give the inner door panel a hard rap with your fist on the 3:00 position directly over the screw hole at the front of the arm rest. One rap and the window worked fine. Happened again 6 months later (two days ago), I gave the door panel a rap and bingo, window works fine. Made an appointment to have the motor replaced under warranty. Give it a try.
Old Jul 23, 2006 | 01:27 AM
ZoomMINI's Avatar
ZoomMINI
Drivers Window
Thanks for the info, mine (March 04) stopped working today, 2 hits to that location got it working again.
Cheers
Old Jul 24, 2006 | 06:19 AM
Johns's Avatar
Johns
Mine stopped working two weeks ago. Took it in and they replaced the motor and regulator for free.
Old Jul 28, 2006 | 08:22 AM
xcaligali's Avatar
xcaligali
I guess I need to join the club of passenger side windows that don't roll down. Happened yesterday ... waaahhhh!!!
Old Jul 28, 2006 | 10:33 AM
acitydweller's Avatar
acitydweller
this is a common problem with bmw's in general.
Old Aug 9, 2006 | 07:27 PM
peccavis's Avatar
peccavis
Just happened to me today Did the whack-a-job on the door (described above) and voila!
This forum is awesome!
Old Aug 9, 2006 | 08:20 PM
imthing1's Avatar
imthing1
something similar happened to me. My driver's window makes a clicking noise when going up and down. Hasn't stopped working yet, but Mini says it is the regulator, it will be replaced as soon as the part is ordered.
Old Aug 10, 2006 | 09:43 PM
smf's Avatar
smf
This just happened to me tonight... 03 MCS
That two raps at 3 o'clock trick is DA BOMB.
Thanks jfhaia, great advice.
I love this website.
smf
Old Sep 4, 2010 | 07:49 AM
liogod's Avatar
liogod
Hit just to the right place and...bingo!!!
Old Sep 4, 2010 | 03:00 PM
Hotzmini's Avatar
Hotzmini
As a chiropractor you can imagine my joy when I heard 1 good thump would fix it. Even better was the look on my wife's face as the previously dead window slid down gracefully. Thanks NAM for making me look like a hero.
Old Feb 6, 2011 | 01:21 PM
TinaKet's Avatar
TinaKet
You rock! I just tried this trick and my window is working again! I've dubbed it the Fonzi method.
Mil gracias!
Old Feb 10, 2011 | 09:41 AM
Neufusion's Avatar
Neufusion
Mine just decides to magically start working again on cold SoCal days and then will keep working for weeks or months and then fail for weeks or months. This morning at 34 degrees it started working again after weeks of hibernation.
Old Apr 23, 2011 | 04:35 PM
livewellandfree's Avatar
livewellandfree
Mil gracias!
Ayyyyy!!!!! My 2003, with 147k went "click, click"... Fonzi, you're the man! (That was so much easier than replacing the superchager!)
Old Apr 26, 2011 | 11:06 AM
Neufusion's Avatar
Neufusion
My passenger side window just started making a loud clank when rolling up or down. It's catching on something because it will push the door lock up when it rolls up.
Old Apr 27, 2011 | 05:46 AM
myles2go's Avatar
myles2go
I've lived with this problem for a few years. This appears to be a heat related problem. The passenger window in my '04 MCS has never failed in cool temps, but only during hot summer days. It also seems that on those hot days, if I open the windows in the morning when it is cooler, then they will work all day.
Old Aug 21, 2011 | 05:29 PM
mplatt911's Avatar
mplatt911
WOW. Just when I thought I would be going through major surgery getting that motor out.......Three smacks on the area near the door handle and whalla! Nice post, finally something easy to fix a problem on these cars.
Thanks!!
Old Oct 26, 2011 | 05:46 AM
ih8cornnuts's Avatar
ih8cornnuts
Thanks so much for this info, when I get home I can finally fix this (slightly) nagging problem on my car. Sometimes it works sometimes it doesn't, although lately it's been in the NOT working category.
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
Dashdog
Aug 10, 2015 06:17 AM
