bad stuff happening to my mini please help
so after installing my alta light bar my car has a few issues. all my lights work except my headlights. my auto a/c is not turning on at all. my tach, speedo, and gas gauge don't work but my obc is working so i can see the digital readouts. i did both software resets and still nothing.
if anyone has any ideas i'd love to not have to visit the dealer for this
i did not wire the driving lights just bolted them up
If all you did was mount the Altas and made no electrical connections, your problems are unlikely to be related to the Alta mounting, so don't be afraid to take it to the dealer.
When you disconnected the Fogs and marker lamps to remove the bumper skin, did you reconnect everything properly?
Recheck the fuses. There are 2 fuse panels (kickpanel and under hood) as well as several independent fuses. Check your owner's manual.
Welcome to MINI ownership. These sorts of things will happen on a regular basis.
i tried the disconnect the battery for 30 min trick no luck
all the lights in the bumper still work i.e. the marker lights
the car was started when the bumper was off and every thing was disconnected
Colt45Magnus
Aug 12, 2015 06:43 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
1964geo
Aug 10, 2015 06:22 AM
nismo4life
Aug 5, 2015 08:31 AM
