Max boost readings in Hg
Old Jun 29, 2006 | 12:57 PM
MSFITOY's Avatar
MSFITOY
I would appreciate anyone else out there with an OBD reader that can tap into the Hg boost/vac and tell me what are your readings at maximum load/rpm...my reading from the OBD in Hg (after conversion) doesn't correlate with my boost gauge in PSI so I'm not sure if my gauge is off...
Old Jun 29, 2006 | 02:48 PM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
I have the safc which does pressure reading in HG. When it use to Pop the SES light which i thought was around the 18+ psi i was getting reading of 1.19 .. as of now i dont pop the light anymore im down to .89 but still putting down 215 whp accorrding to the dyno
Old Jun 29, 2006 | 05:52 PM
haulinS's Avatar
haulinS
hey Sid, just grabbed some quick numbers for ya........
its a lovely 91 degrees F here in Cali. ambient pressure (absolute) is around 29.3 inHg. At 100% load, 6,529 rpm, boost was at 57.4 inHg. hope that helps.
Old Jun 29, 2006 | 08:03 PM
MSFITOY's Avatar
MSFITOY
Thanks much...
Old Jun 30, 2006 | 06:28 AM
MSFITOY's Avatar
MSFITOY
That comes out to 13.8psi
I think I have a boost leak somewhere as I'm not able to break past 53 inHg...and this is with 15% pulley and 2% crank I've checked, double checked, tripple checked everything and am stomped...any ideas guys? Could my SC be toast? I know it lost it's coating a while ago but could that keep it from building boost?
I'll verify my actual boost later today when my digital boost gauge is delivered (0.1psi resolution)...
Old Jun 30, 2006 | 06:37 AM
mdsbrain's Avatar
mdsbrain
How much boost loss is caused by a larger Intercooler? I'm not trying to blame your new M7 DFIC as I'm sure its top notch. But how much loss should be expected from the use of it?
Old Jun 30, 2006 | 06:42 AM
MSFITOY's Avatar
MSFITOY
I've checked the boost readings of both DFIC and stock and the readings were about the same...I have problems elsewhere...
-Water leak down test revealed no leaks in either stock of DFIC units
-Intercooler boots are in very good condition
-Could a bad BPV cause boost leak?...I've gone back to using VGS to take advantage of positive valve pressure from boost.
Old Jun 30, 2006 | 10:09 AM
Revolver's Avatar
Revolver
Have you tried zip-tying the bpv closed? I felt a slight loss of power so I tried the zip-tie mod, the difference was like night and day. My boost gauge confirms a gain of about 1 psi and I get up to full boost much quicker under full load. I don't quite understand how the zip-tie mod could create increased boost as opposed to simply quicker boost, but it did. I'm getting my bpv replaced today!
I have tried a couple of boost gauges by the same manufacturer and they show slightly different readings, so I don't consider their numbers absolute. (Unless it was just my installation which is entirely possible.) So...minor threadjack...can anyone recommend an OBD reader that can tap into the Hg boost/vac? Thanks!
Old Jun 30, 2006 | 11:45 AM
MSFITOY's Avatar
MSFITOY
I don't recommend using the zip-tie fix as it will load your SC all the time and your output plenum's temperature will go through the roof (had a stuck bypass valve and found out the hard way).
I am using Auterra/Palm OBD diagnostic/reader to see the actual inHg...
Old Jun 30, 2006 | 01:23 PM
Revolver's Avatar
Revolver
Oops, thanks for the info...but just to diagnose the issue I mean...anyway I hope it helps in some way.
Old Jun 30, 2006 | 06:14 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I'd say your BPV leaks a bit...
I've had the same problem, and changed for a DetroitTuned BPV. Full boost now and a happy driver lol
Old Jun 30, 2006 | 06:52 PM
MSFITOY's Avatar
MSFITOY
I'm going to check that when AGS-V3 shows up...I don't know how it could go out of adjustment since I checked it my self the last time I opened it up...
Old Jun 30, 2006 | 07:52 PM
DarkMiniCooperS
Does it close fully and the seal is good?
Also, the DetroitTuned BPV has a stiffer spring which really makes a huge difference. And the best part is that it didn't hit that much (in fact not at all) my fuel economy...
Old Jun 30, 2006 | 08:37 PM
MSFITOY's Avatar
MSFITOY
I'll have to see if Chad has one floatn around when he comes by tomorrow for our BBQ
Old Jul 3, 2006 | 07:33 AM
MSFITOY's Avatar
MSFITOY
Mystery solved...essentially...there was no mystery other than the Autometer's junk:impatient After installing the high resolution boost gauge, my reading proved to be normal...15.7psi normal max and sometimes reaching 16.2psi
The gauge was temporarily mounted next to the Autometer for comparison...it has since replaced it
The boost tap is directly from the DFIC. I will be rerouting the tap line to read from either pre-IC and/or post-IC in a few days...
Old Jul 3, 2006 | 08:33 AM
SpiderX's Avatar
SpiderX
Very nice Sid..... I'm glad it is all sorted out......
In the audio world we have three classifications
1) consumer
2) semi-pro
3) pro
and there is a 4th but not in my market - audiophile
the auto meter seems a bit questionable as to its intended market
Old Jul 3, 2006 | 02:45 PM
MSFITOY's Avatar
MSFITOY
1) consumer
2) semi-pro
3) pro
I guess "Miniphile" equipment are harder to come by
Old Jul 3, 2006 | 05:01 PM
DarkMiniCooperS
Just out of curiousity, does your Autometer and digital gauge show the same readings or there is a little difference?
Old Jul 3, 2006 | 07:15 PM
MSFITOY's Avatar
MSFITOY
Difference? The Autometer goes "bzzzzzzz....12, no maybe 14, no maybe 15...naw just kiddn...how about 12 instead?":impatient It vibrates so badly that the only thing I can tell is that there is air in it The digital gauge is accurate to 0.1 and no BS inbetween...
BTW...anyone want to buy a used Autometer boost gauge? It's really not that bad
Old Jul 3, 2006 | 07:25 PM
DarkMiniCooperS
Hummm... That's strange...
My Autometer gauge is not doing that... Maybe yours is broken??
I,ve never had any problems with Autometer gauge, either in my Subaru or MCS
Old Jul 3, 2006 | 07:53 PM
MSFITOY's Avatar
MSFITOY
You probably have the electric version right? They're better but still not very accurate IMO...
Old Jul 4, 2006 | 12:29 AM
BFG9000's Avatar
BFG9000
Mystery solved...essentially...there was no mystery other than the Autometer's junk...
I think you need to work on your sales pitch
lweaver
Sep 17, 2024 08:22 AM
Filmy
15
Jun 6, 2023 06:27 AM
paul7878
Sep 14, 2015 07:44 AM
mbatech
Sep 10, 2015 03:40 PM
Sep 2, 2015 11:15 AM
