PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 [66] 67
  1. 34 MPG MCS!
  2. Driveway Whine
  3. Help! My cooling fan won't stop running...
  4. Windshield Problems
  5. I'm really worried...smoke from the engine
  6. Seat Belt light problem
  7. Towed to Dealer again!
  8. Jump Starting Problems!
  9. Grinding Gears...
  10. Attention: CVT Mini Owners RECALL!
  11. Conversions and speed
  12. transaxle lube
  13. Do your brakes squeak?
  14. MCS: Supercharger? Roots or Eaton
  15. Cooper Works Upgrade
  16. Poor Sick Mini (RIP?)
  17. Steering hydrolic excessively loud?
  18. Black soot on tailpipe
  19. idle still dropping on MC
  20. Something to check...
  21. Knocking / Clunking Sound Front Left Suspension
  22. Xenon Headlamps pointing to the right? right or wrong?
  23. Problem!!!
  24. My Poor Sick Mini >>
  25. MINI recalls CVT transmissions
  26. shallow socket
  27. NEW Gearbox and clutch installed.
  28. mini s engine jolts, service engine soon lit, then dies.
  29. I broke my coin cup (ashtray)
  30. Coolant level?!
  31. Mechanic Book for Cooper of Cooper S??
  32. Questions from a New Owner
  33. SPARKPLUG WIRES & RODENTS
  34. Oil filter sold at BMW dealers?
  35. Extended service warranty
  36. steering rack failure
  37. My MCS is pulling to the Left
  38. Headlight noise?
  39. Lazy, Blinking Oil Pressure light
  40. Tire Pressure Indicator Light
  41. Leatherette Seats
  42. Must Read for anyone thinking about modifying their car to i
  43. Which Suspension Do I Have?
  44. mini mania's parts are too expensive
  45. Headlight Problem
  46. LP/natural gas conversion?
  47. My Poor Sick Mini (PART TWO) ****
  48. MAJOR CLUTCH PROBLEM!
  49. first service
  50. MINI-issued Recalls for the MC or MCS
  51. Power Curve
  52. Lighting bulb upgrade
  53. Help please! I need someone to measure something on their MI
  54. CVT Sport Drive
  55. Similar but Different
  56. BMW Coolant works in MINI
  57. wire routing thru firewall
  58. Fuel economy reads high, odometer reads low, and speedometer
  59. Sunoco 94 octan
  60. steamy supercharger (related to coolant?)
  61. Amsoil VS. Mobil 1
  62. Mini CAR ALARMS?
  63. Oil Filter Socket
  64. Question about the brakes
  65. MINI-Motorsport
  66. Does LUCAS lurk under the bonnet?
  67. Headlight anger...
  68. scrathing brakes noisy shifter
  69. 500 mile oil change on new MINI?
  70. auto door locking, anyone?
  71. Cams
  72. My poor sick Mini
  73. Coolant loss
  74. A useful site for Mini owners
  75. Toggle Switch Panel
  76. Turbo for the Cooper...
  77. BMP Intake...Order or not to Order...that is the question.
  78. Driving Light Mounting Points
  79. 10k miles, no free oil change
  80. Acceleration Problem
  81. water pump
  82. H&R lowering springs
  83. floormats
  84. Xenon not auto leveling
  85. Baffled???
  86. Many Mini Problems
  87. Performance Garages for Mini's
  88. Who has a rear power socket?
  89. mp3 connection?
  90. BMP AIR INTAKE ???
  91. performance #'s for 200hp kit ?
  92. Soundproofing insulation in my air filter?
  93. Coolant loss in Cooper S
  94. ordering aftermarket goodies?
  95. Getrag transmission fluid type?
  96. Airbag Warning Light On
  97. Boot Lock problems - quick fix
  98. HELP Needed.....
  99. Insta-Stall
  100. RPMs still dropping after CD31
  101. Driver's door won't open!
  102. Driver side window needs new motor!
  103. supersprint exhaust
  104. Hot Air w/ Auto AC off.
  105. airbag light....
  106. Brake Dust
  107. Problem Starting Today
  108. Under Drive Pulley
  109. Anyone ever used one of these?
  110. Stalling in reverse
  111. Wheel Dimensions
  112. Jacking Points
  113. Help with a problem that I have no idea what it is...
  114. Engine Dressup Kits
  115. Power Steering
  116. Oil Treatment
  117. Fresh Air
  118. "clunk" sound after turn off?
  119. Seat Return problem/question
  120. Steering fan?
  121. Couple of questions regarding MCS...
  122. My MINI keeps whistling at me. . .
  123. Problem with driving lights
  124. Oil Change?
  125. Neat little storage compartment for in front of the shifter.
  126. Anthracite trim/16" vs 17" wheels.
  127. Chiltons/Haynes Manual
  128. Rear Deck Lid Latch
  129. Engine Longevity
  130. Survey : Your/normal engine temperature gauge reading?
  131. chrome trim
  132. Window washer fluid level?
  133. Another rattle... front seat-belt mechanism
  134. blinking outside temp reading
  135. Defroster
  136. Hold Down Odometer Reset Button and Numbers come up
  137. Water in my tail light housing
  138. Headlight questions
  139. Changing the oil in my Mini
  140. Body Kits
  141. tire pressure sensor
  142. Mysterious rattle solved - now you know.
  143. 6 Speed for the Cooper
  144. mud guards
  145. Really just a Neon?
  146. Extended Warranty on Mini
  147. Runnin' a little hot
  148. Electrical problems?
  149. scratching noises when turning?
  150. Programmable upgrades and stumbling at idle software fix CD
  151. service engine soon light
  152. Dip Stick
  153. ECU Update - CD #32
  154. Coolant color change.
  155. Some notes Noack Volatility
  156. Oil changes done by Mini
  157. from 5 to 6
  158. Synthetic Oil
  159. Turbo kit on the way in November!
  160. APR not currently planning to develop performance MINI parts
  161. No Power in First gear????
  162. FORGE Motorsport Aftermarket parts for MINI
  163. Another Cool Thing from MINI USA
  164. Oil consumption ?
  165. Window Problems
  166. Blower
  167. Color choice
  168. Whistle or Whine from 1500 RPMS up MCS (June 7 build)
  169. Break-in period
  170. NEUSPEED Aftermarket parts available soon for MINI
  171. Radiator Leak.
  172. John Cooper Works exhaust installed
  173. Most problems solved
  174. MINI Truck Problem
  175. Are the heated seats pulsing heat?
  176. Problem while waiting in traffic...
  177. information on mcs engine
  178. decelleration hesitation
  179. Upgrades ????
  180. WET FEET!!!
  181. Break in time line ?????
  182. hesitation in first gear cooper
  183. um...automatic?
  184. water leaks into car at doors
  185. Rattling, rattling, rattling
  186. downshifting
  187. Aero kit
  188. Forget About Expensive Exhaust Mods, Try This.
  189. Pictures of Gages For MCS
  190. Transmission Dip Stick?
  191. Water flowing sounds from front Left
  192. Mini Cooper S 2003 Glovebox
  193. Studded run flat tires
  194. Removing Cooper's Space Saving Spare
  195. Honda Steel Wheels
  196. Flat Tire Warning
  197. Oil Filter Socket Source
  198. Toggle Switches
  199. auxillary fan
  200. Fuses: What do they go to?
  201. MINI Mantenance Manual
  202. MINI Tachometer Redline.
  203. Break in period
  204. MINI Rep
  205. cold start issues
  206. LED display going bad
  207. My Cell phone ate my Mini....................
  208. FIRE!!!
  209. Factory Alarm
  210. Cooper s Run Flats...
  211. K&N part Number
  212. Castrol Synthetic???? Car and Driver 11/200
  213. Great Article on MC in Grassroots Motorsports
  214. Super Charger and Altitude
  215. What changes have you noticed after 1200 miles?
  216. What do you keep your cold air pressure in the 15 inch tires
  217. Anyone own a CVT??? Please tell!!!
  218. Upsizing tires...What about the speedo?
  219. Alarm
  220. Cooper won't start!
  221. A/C pulley ratio...
  222. Suspension System
  223. Traction control - reversing the circuits!
  224. Moss MINI High Flow Intake Filter
  225. accidents
  226. mpg
  227. OBDII
  228. RSpeed now offering JCW exhaust
  229. Recommended Oil Weight
  230. My foglamps aren't what they say they are!
  231. WHeel offsets
  232. PROBLEM WITH NEW LEATHER DRIVERS LEATHER ON MY MINI COOPER S
  233. Velvet Red Mini Here, almost
  234. After market Exhaust
  235. Broken seat latch
  236. Newbie here
  237. Panic stop and the EML light
  238. Run-flat owners beware! Most expensive cup of coffee you'll
  239. Magnecor wires before or after 1200 milesw
  240. NE1 replaced a Dunlop 17" Runflat?
  241. Oil Filter Part #
  242. Who Hasn't Had Trouble With Their MINI?
  243. Cooper "S" Modifications???
  244. Something Odd posted up on EVO...
  245. Boost&weight
  246. Curious about factory roof-rack
  247. Cracked pulley and tie rod problem on S
  248. MINI Car Club of America
  249. Throttle Body Busted
  250. Auto Door locks as you drive off
