Fresh Air
Old Oct 23, 2002 | 09:30 PM
1lesssuv's Avatar
1lesssuv
Driving home from work I usually pop open the sun roof and windows and turn the Auto climate control off. Funny thing is it insists on blowing hot air through the vents even when off (outside temp 66 here in San Diego last few days my thermostat set to 72 but TURNED OFF!) Is this normal or is something broken?
Also my little computer seems to accuratly register outside air temp but when I toggle to the other setting they always read 25mpg and 27mph even if I'm going 80 in sixth gear. What Gives?
Old Oct 23, 2002 | 09:53 PM
acetonic's Avatar
acetonic
I havent experienced the outside air problem. Mine seems to be the outside temp when climate control is off.
As for the mpg and mph numbers. those are just averages since the last time you reset them. if you have driven for 1000's of miles, driving 80 for a while wont change the averages. i reset these everytime i go on a trip. and you can watch the numbers change pretty fast. its fun to reset the mpg just when you are coasting down a long hill. yay 99mpg!
Old Oct 24, 2002 | 04:31 PM
CCM's Avatar
CCM
Yes, that's normal. Even with the auto climate control off you will still blow hot air if you left the temp. setting at, say 70. If I turn mine to "Lo" before I turn off the auto climate control it'll blow the outside temp. air. Or simply don't use the auto climate control button at all. I only used the auto climate control in the summer for the A/C. I find it more comfortable to use only the air speed and temp. setting manually.
Old Oct 24, 2002 | 04:49 PM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
The computer runs an total average. If you reset the computer when you get on a fast moving road, you'll see the average go up. Do this by pressing the button to get the display you want to reset, then hold the button down for two to three seconds. Same with the MPG display of the computer. Reset it after every fill up and you'll get the average MPG between fill ups.
Old Oct 24, 2002 | 05:01 PM
DrkSlvrS's Avatar
DrkSlvrS
If you turn the auto climate control to a lower setting then your outside air, then turn it off, it will blow cool air rather than warm.
Old Oct 25, 2002 | 08:06 PM
ChrisCooper's Avatar
ChrisCooper
Old Oct 28, 2002 | 01:31 PM
Eggsav's Avatar
Eggsav
I have had my MC for 4 months and I have finally figured out the auto climate control. In the summer, if it is off, make sure the recirculate is illuminated so you don't get hot air blown on you, or push the off button when the unit is off and adjust the fan speed to zero with the recirculate on! :smile:
Old Oct 29, 2002 | 12:29 AM
Babs's Avatar
Babs
Ha!, I AM vindicated for deleting the auto climate from the package (but paying full price)! I had auto climate in a Saab and hated it. Give me manual control anyday!
Southern Marylander
18
Sep 18, 2015 07:16 PM
Norton70
Sep 7, 2015 05:06 PM
M7Speed
Sep 4, 2015 10:47 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
