Castrol Synthetic???? Car and Driver 11/200
Old Sep 7, 2002 | 10:20 AM
2minis's Avatar
2minis
Synthetic Motor Oil Gets All New Semantics
(first published in Nov., 2000 issue of Car and Driver by Patrick Bedard)
Now that the meaning if "is" has gotten so slippery you need to grab it with both hands, we'd better keep an eye on longer words, too.
One's already got so squirmy on us- "synthetic," as in synthetic motor oil.
Most guys know two things about synthetic oils. First, the price is three to four times that of conventional oils. Second, they're not real oil, not made from crude.
News flash: Scratch that second part. Now motor oils derived from crude may be labeled "synthetic." But they still cost over four bucks a quart.
Bait and switch? That's the obvious conclusion. Except in this case the advertising ethics people have given their approval.
Here's what happened, according to a detailed account published in the trade magazine Lubricants World. Late in 1997, Castrol changed the formula of its Syntec "full synthetic motor oil", eliminating the polyalphaolefin (PAO) base stock (that's the "synthetic" part, which makes up about 70% by volume of what's in the bottle) and replacing it with a "hydroisomerized" petroleum base stock.
Mobil Oil Corporation, maker of Mobil 1, "Worlds Leading Synthetic Motor Oil," said no fair and took its complaint to the National Advertising Division (NAD) of the Council of Better Business Bureaus. NAD often arbitrates between feuding advertisers on their conflicting claims.
The notion behind synthetic motor oils as we've known them is an elegant one. Instead of relying on the cocktail of hydrocarbons contained in crude oil, why not go into the laboratory and build the perfect base stock from scratch, molecule by molecule, and builds it till it gets 10-carbon molecules, then combines three of those to form PAO. The result is a fluid more stable than the usual base oils derived from crude. It keeps flowing at low temperatures. It's more resistant to boiling off, and more resistant to oxidation, which causes thickening with prolonged exposure to high temperatures.
Still, there's more than one road to the point B of improved stability. Petroleum refiners in recent years have learned how to break apart certain undesirable molecules - wax, for example, which causes thickening of oil at low temperatures- and transform them by chemical reaction into helpful molecules. These new hydroisomerized base oils, in the view of some industry participants provided properties similar to PAO's but only cost half as much," Lubricants World reported.
The argument before NAD tiptoed around the obvious- does the consumer get four bucks' worth of value from each quart of synthetic oil?- and plunged straight into deep semantics. Mobil's experts said "synthetic" traditionally meant big molecules built up from small ones. Castrol's side held out for a looser description, defining "synthetic" as "the product of an intended chemical reaction."
What do unbiased sources say? It turns out that the Society of Automotive Engineers (SAE) and the American Petroleum Institute (API) both have technical standards covering motor oils, and both of these organizations in the '90's backed away from their old definitions of "synthetic," leaving lots of room for new interpretations.
In the end, NAD decided that the evidence constitutes a reasonable basis for the claim that Castrol Syntec, as currently formulated, is a synthetic motor oil, said Lubricants World.
The obvious question now: Has the term "synthetic motor oil" been opened up to the point that it no longer means anything? Maybe. But here's a better question: Did synthetic ever mean what we thought it meant?
"Great oil" is what most guys think it means. "At that price, it's gotta be great stuff!"
Okay, but how great? Your cars manual tells what motor oil you should use, and with few exceptions, that description will consist of only two specifications. One is for viscosity, such as 10W-30; and the other is for the API service grade, SJ being the current one for gasoline passenger cars.
The buck-a-quart multi-grades meet these standards, as do the synthetics.
The synthetics, on the back label, claim compliance with more standards, but even if you know what they mean, they seem beside the point for U.S. passenger cars. For example, should you care about diesels if you drive a gasoline burner? API service CF is the oldest of the current specs for light-duty diesels; some synthetics list that one. Synthetics may also list ACEA A1 and B1, which are European specs roughly equivelant to API gasoline and diesel specs. The Europeans grad their oils by level of performance, so that A2 and A3 are tougher specs than A1. Same for diesels. Usually the date of the spec is omitted, but A1-98 is newer than A1-96.
Completely absent is the one performance claim that would have some real meaning for all of us- some indication of longer oil life. (except for AMSOIL which clearly states 25,000 miles/1-year or 35,000 miles/1-year for their Severe Service 0W-30 synthetic). Automakers hold synthetics to the same oil change intervals as conventional oils. And the oil companies, promise even less. "To give added protection and life to your engine, change your oil every 3000 miles." This same language appears on the back of both Penzoil Synthetic and conventional oils. Valvoline synthetic makes a similar recommendation. (commentary: Since 1972 AMSOIL is the ONLY synthetic oil manufacturer in the world to guarantee 25,000 miles or 35,000 mile oil change intervals and utilizing full PAO synthetic technology exclusively).
Synthetics do get one unambiguous endorsement: Corvettes, Porsches, Vipers, and all AMG models from Mercedes-Benz come with Mobil 1 as the factory fill.
Most synthetics mention GM 4718M in their list of claims; that's the unique spec created by General Motors for Corvette oil. It's a high-temperature requirement that tolerates less oxidation (thickening) and volatility (boil-off) on a standard engine test called Sequence 111E according to engineer Bob Olree of GM Powertrain. (note: AMSOIL 0W-30 far surpasses GM's 4718M spec).
But don't expect to learn such details on any label (again, except for AMSOIL which clearly states test results on the back of every bottle of Series 2000 0W-30 and 20W-50 synthetic). Mobil 1 at least uses straight forward declarative sentences. Most of the others read as though they were written by a lawyer looking for an escape clause. Why else would the following claim be so rubbery? "Penzoil Synthetic motor oil is recommended for use in all engines requiring ILSACGF-1, GF-2, API SJ, SH, or SG, and in engines requiring oils meeting GM 4718M." Okay, but does it actually pass those standards?
"Yes" says James Newsom, Penzoil's motor-oil product manager.
Castrol Syntec, on its label, "exceeds" every standard it mentions. Hmm. Now that the meaning of "is" is in play, I have to wonder, does Syntec meet those standards as well?
"It does" says Castrol's Julie Ann Oberg. While I have her on the phone, I ask if there will be a Syntec price reduction now that the lower-cost base stock has been substituted for the old synthetic. She says no.
End of article.
Now, after reading that why would anybody in their right mind want to spend their hard-earned money on Castrol Syntec, Penzoil Synthetic, Valvoline Synthetic or any of the other "synthetics" when what your getting is not even a true 100% full PAO synthetic? Even Mobil 1 Tri-Synthetic uses multiple base-stock technology by blending other synthetic molecules with the PAO base-stocks and then they come up with a catchy name of Tri-Synthetic. Pretty sneaky huh? AMSOIL moved away from multiple base-stock technology over 20 years ago!, yet Mobil makes it sound like their Tri-Synthetic technology is some new earth-shattering technology. What a joke!
Why not skip all the hype and deception of these other manufacturers and just use AMSOIL? AMSOIL uses only 100% full synthetic PAO technology in each and everyone of its motor oils and is the undisputed leader in synthetic engine oil technology as well as the leader in synthetic gear lubes, transmission fluid, greases, two-cycle oil and many other lubricants and hydraulic fluids. Today, virtually every other motor oil manufacturer has recognized the superiority of synthetic lubricants and has followed the AMSOIL lead with introductions of "synthetic" motor oils of their own.
:evil: NOW WHAT?
Old Sep 7, 2002 | 10:26 AM
2minis's Avatar
2minis
By the way, I changed my first Cooper at 4000 and the S I now have I'm changing at 1200....and then every three. Am I nuts? I do drive "hard."
_________________
MiniMe
Old Sep 10, 2002 | 07:13 PM
2minis's Avatar
2minis
Anyone have any info. re. this 'beneath the bonnet' topic?
Old Sep 10, 2002 | 07:31 PM
Shaguar1's Avatar
Shaguar1
Does Synthetic oil keep the gaskets from leaking? I went to synthetic oil on my vehicle and the whole engine became covered with oil due to oil seeping out of the gaskets. Some said that the synthetic oil did not carry the contaminants that normally would block up the leaks...????
Old Sep 10, 2002 | 10:08 PM
Zappa's Avatar
Zappa
Amsoil does use additives to prevent that for seals already in good condition. If you use a good synthetic in time it also prevents the deteriation of seals in a proactive matter due to its abilty to transfer heat and retain its viscosity. Our ATF also prevents transmission leakage problems.
Old Sep 10, 2002 | 11:39 PM
Newkevin's Avatar
Newkevin
Interesting.
But am I to assume that Mobil 1 is still 100% synthetic?
And is that the better choice for the Mini (except for maybe Amsoil?)
Old Sep 11, 2002 | 07:24 AM
Zappa's Avatar
Zappa
Mobil 1 is fine. Amsoil would actually cost you less. Mobil 1 does not guarantee their products. And although it doesn't weigh in much here, Mobil 1 does not meet specs for CH-4 and other new upcoming API requirements.
If you were to try the Amsoil 0W-30 without even using a dyno, the feel, sound and efficiency of the engine you gain will surprise you and like all my customers, you will never switch back. Many go with Amsoil because of the wide range of products available. Top rated gearlubes (lifetime guarantee), fuel and injector additives that cost less, filters, etc.. Email for a catalog.
Old Sep 19, 2002 | 07:26 PM
Mjolnir's Avatar
Mjolnir
The dealer told me that oil changes are included in the first 3 / 36 portion of the warranty and the first oil change isn't until 10,000 miles.
Am I a fool to believe that?
jayoung@mailbag.com
Thanks!
Old Sep 19, 2002 | 07:30 PM
Azwed's Avatar
Azwed
>>jayoung@mailbag.com
>>Thanks!
With Amsoil or some of the other synthetics(Redline, Royal Purple, possibly Mobil 1) i would say 10,000 is no problem but not with the Castrol since it is crap.
Old Sep 19, 2002 | 07:40 PM
andrew's Avatar
andrew
Anyone notice Castrol logo next to MINI oil levelstick on engine casing?
My MINI was 1/2 quart low after 3500 miles, so I hope people are chaecking and not waiting for 10,000 !!!! I added 5/30W Mobil One. Dealer recommended that along with BMW 5/30W......FYI
Old Sep 25, 2002 | 02:34 PM
BrunoBMW's Avatar
BrunoBMW
If you've done your homework and spent hours in front of the computer reading report after report, you'll come to the conclusion that AMSOIL is currently the best product out there. I put it in my '86 535i (188,000miles) at the urging of my local mechanic and was surprised at how smoother the engine sounded. So now it's in everything, motorcycles, '66 Chevy and lawnmower. But until I'm convinced using it in my "S" won't void my warrenty, I'll stick with Mobil 1.
Old Sep 26, 2002 | 03:07 PM
sirron's Avatar
sirron
BrunoBMW
How is anyone going to know what oil you have in your Mini when you take it for service? Do you think that the technician will send it for analysis or just dump it, along with all the other dirty oil as quickly as possible to get to the next job to earn more money? Use Amsoil, it's the best! Ron.
Old Sep 28, 2002 | 02:19 PM
Azwed's Avatar
Azwed
They can't void your warranty as long as the oil you are using meets the minimum API certification for that year vehicle.
There is a federal law about it which I think is called the Magnus and Moss act or something similar.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
Minibeagle
Aug 13, 2015 10:00 AM
xpunisherx
Aug 10, 2015 10:50 PM
