PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67
  1. Aux Oil Cooler Kit
  2. OBDII software
  3. Help.. need parts number
  4. Engine Code P1237?
  5. Manual Transmission Failure at 1950 Miles
  6. Washer Fluid Resivour/Pump/Jets Problem
  7. 05 Flywheel Problems
  8. need help with a boost gauge
  9. Love MINI. Fed up with service.
  10. Driving while in Limp Mode warning!
  11. Gas Gague Calibration curve - lower half of gauge
  12. What are best OEM Alarm Memory Settings
  13. A/F Ratios in non-WOT non-boost situations
  14. Flat tire warning light failure
  15. Parking "P" on shifter is lit when car is not on
  16. MPG (S models only)
  17. Crack noise from driver seat
  18. rattling coming from the ac/toggle switch area
  19. Heater Core Replacement
  20. '05 LSD noise.
  21. A/C Issues
  22. Which is the best place to get an oil filter?
  23. How can I replace a foglight without removing the bumper?
  24. Water + Battery = Not Good
  25. Coolant change ?'s
  26. New rumbling after installing Alta intake?
  27. Anyone knows what that is?
  28. Supercharger Whine
  29. Vortex Generator for MCS
  30. What is this?
  31. Suggestions?
  32. Any ideas?
  33. Latest Factory ECU version, whutcha got?
  34. Acetone ???
  35. My Lemon Law woes on my 2005 MCS.
  36. rough idle after V42.1
  37. Extra work done that I didn't know about
  38. Another Auto Transmission Failure
  39. Last ditch effort.
  40. Removing '05/'06 dash anyone?
  41. Service Engine Light On
  42. Have plugs, about to get wires/coil pack
  43. Bad S/C bypass valve? MCSa
  44. Transmission rattle
  45. What do you think: Turbonator, Tornado, Spiralmax??
  46. Passenger Side Airbag seat sensor malfunction?
  47. Starter motor nearly causes fire!
  48. Secret to re-attaching air intake snorkel
  49. Brake Fluid replacement- Free?
  50. Bad Experiance!!!
  51. I threw a belt, HELP!
  52. Mini had a Stroke! Left Eye droops
  53. 06 MCS Tuning Questions.
  54. M7 Venom Nitrous Kit
  55. Haltech and Cooper S
  56. Code P1125?
  57. help Please!!
  58. EMS: Haltech
  59. What's that "releasing" feeling when slowing down?
  60. Rev limit question...
  61. Autolock @ 100+MPH or emergency manuver???
  62. what's the air flow?
  63. 6 speed conversion
  64. '05 transmission mapping problem
  65. Cruise control inop and other problems
  66. Reset Service Interval... what else?
  67. EML, SES, and DSC Lights ON! Towed to dealer!
  68. Package shelf suddenly gets in way of hatch closing?
  69. Shock tower mushrooming
  70. xenon headlight problem
  71. After market air filter... voids the warranty?
  72. K-Buss Problems?
  73. Suspension feeling diff?
  74. Is the motor mount oil filled?
  75. Droning noise after curb incident?
  76. Which do you suppose is more accurate?...
  77. Speedo Question
  78. Valve Timing and Size
  79. Water Temp. Problems?
  80. Backfiring upon starting, cold idle. Door handle sticking. Anyone else?
  81. Flat tire monitor
  82. No 2nd gear
  83. SES light.
  84. any brand type ok??
  85. The right side of the radiator back side is obscured...
  86. hood doesn't close completely
  87. MINI service warranty issue with pulley install-need advice
  88. When should I see Boost on Dealer Boost Guage Option?
  89. AUTO TRANSMISSION FAILURE @ 1,500 Miles
  90. O2 sensor replacement Q
  91. Mini maintenance
  92. A/C Compressor on National Back-Order?
  93. Who's car eats oil like mine?
  94. Who manufactures the '06 Mini's engine and where is it assembled?
  95. PDC not working
  96. To C4 - Need a CVT Fixed!
  97. Remote Door Locks - MCS/2002
  98. Strange transmission noise...
  99. Break In / Oil Changes & Flush
  100. How do you determine if a O2 sensor is bad?
  101. Flush Oil or Change Filter?
  102. Question about the Supercharger...
  103. Any Problem using NAPA GOLD oil filter?
  104. 15k between service??
  105. fresh air vent
  106. What should my first mod. be???
  107. phone numbers for mini parts depots
  108. Engine questions
  109. Supercharger stopped working....
  110. Second Oil Test Result
  111. MCS experiencing power loss as it moves up on the power band
  112. alta air diverter install?
  113. Intermitant Loss of Power
  114. shotting flames.....
  115. anyone wieghed there mini......
  116. P1688 Error Code
  117. Loose turn signal stalk
  118. Power Steering Protection ?
  119. Changing Driving Light Bulb
  120. My MINI sounds like crap.
  121. Performance Coatings- Ceramic Coating w/pics
  122. Motor Silk engine treatment
  123. MCS Bumper Cover fit on a Base model??
  124. HELP! Problems from track day...
  125. Help - Keeps throwing P0108
  126. Oil changes
  127. Electrical Gremlins??
  128. Engine knock!
  129. White Smoke in the mornin
  130. URGENT HELP NEEDED-Engine fan keeps running!
  131. Clutch problems?!?
  132. Oil change tips???
  133. Oil breather? Line from valves to intake??
  134. Air Bag System
  135. CVT Help Needed
  136. Trouble Code Identification
  137. What's the best service manual?
  138. bad brakes
  139. Brake drag
  140. Throttle body question
  141. V43 update
  142. MCS factory manual
  143. Radiator fan makes horrible sound when running
  144. Slipping Belt Noise from the Clutch?!?!?
  145. installed own pulley , might have issue
  146. ok this is an odd on, anyone else?
  147. New MINI, and something fell off.
  148. Question re: supercharger pulleys
  149. Out Motoring Ignition Upgrade
  150. Rattling at idle
  151. MCSa, SES, EML, Limp Mode and Exhaust Bolts
  152. Map light cluster buzzing
  153. Intercooler INSTALL Torque
  154. High beam garage door opener install.
  155. need install instructions for belt tensioner on MCS
  156. Engine Replacement - stroker kit?
  157. Malfunctioning Xenon headlight washers!
  158. new '06 MCa not shifting easily
  159. Catalytic converter options
  160. Need Mini Deal that will ship parts
  161. MiniUSA response to fuel.
  162. turner motorsports
  163. I need some help or advise
  164. Cold start & JCW cars?
  165. Software version v43?
  166. MINI engine blew the cylinder wall out PICS!!
  167. need help, rear Fenderflare light
  168. Boost Gauge Install Q
  169. non synthetic oil
  170. Strainer inside brake fluid reservoir--necessary?
  171. Alta Intake install problem! HELP REMOVE BOLTS
  172. Water temp. sender for after market gauge
  173. question on changing air filter
  174. Driver side window not working
  175. There are two ball-joints per control arm, why do online parts houses only list one?
  176. Clutch grinding in Reverse?
  177. serives engine soon
  178. Clack when accel. and Double clack when decel.
  179. Leaking OIL COOLER ... Anyone else have one ???
  180. Fogging Headlights
  181. Thar's Water in My Mini!!
  182. Clicking sounds from steering
  183. Cost of New Clutch
  184. Steering Rack leaks into boot - can seals be replaced?
  185. pulling to one side or the other while in gear? also noise from rear when breaking?
  186. Question on a different engine noise...
  187. Yet another f'd up service story.
  188. Broken Door Lock
  189. Anyone replace a front control arm (wishbone)?
  190. Oil Pressure Meter Hook-up
  191. Xenons not working?
  192. Anyone replace their MINI horns with this one?
  193. MCSa WARNING!!!
  194. Air filter for MIN Cooper
  195. a uniquely urban problem -- rats
  196. Storing my MINI for a year....questions
  197. Fuel Injection cleaning
  198. Heres a weird first for me, problem wise? let see who can get this one
  199. My '05 MC is getting a new transmission!
  200. Windows squeal?
  201. Poor Windshield Wiper Life
  202. Steering wheel swap, 3 spoke -> 2 spoke. Will the buttons still work?
  203. boot/bonnet light stays on????
  204. Dumb question about Rhino ramps
  205. Oil drain plug washer?
  206. So is my dealer feeding me a line should I be upset??
  207. Steering fluid level???
  208. Mini Madness vs. Dinan (Engine Performance/HP Boost)
  209. Home made ramps?
  210. can octane be too high?!
  211. removed JCW air cleaner and liking it!
  212. How do you change the oil?
  213. Keyless entry stopped working, driver side only??
  214. freakin' Mini service center!
  215. interfacing question
  216. Larger Throttle body 62mm
  217. Xenon Headlight Leveling Problem
  218. Chrome engine detailing?
  219. Radiator overflow issues
  220. xenon problems
  221. Door Casing Color with Grey Leatherette
  222. All about spark plugs
  223. Aftermarket ECU options
  224. xenon headlight auto-adjust
  225. normal for stock exhaust?
  226. Does your clutch do this?
  227. optima battery for mcs??
  228. Supercharger Belts for smaller pulleys
  229. New Alta Exhaust
  230. Rubber piece hanging from bottom of rear suspension..
  231. Oil Change/Service
  232. question
  233. 2005 issues...
  234. Is a shop manual available for the MC?
  235. normal noise or not normal?
  236. ALTA CAI Install Instructions
  237. MINI tracking on uneven surfaces, normal?
  238. Grease leaking from hole in boot..
  239. Cold Start Testing - With Data
  240. Radiator hose size?
  241. Does the MC have a knock sensor?
  242. Anyone Over 100K Yet? Any Problems..Major/Minor?
  243. Let the modding begin!
  244. P0234 code
  245. creak and leak in rear suspension
  246. Bouncing Boost, Whats going on?? Help!
  247. Special Thanks:
  248. rear vibration and tapping
  249. Gas Gauge Accuracy
  250. MINI Clutches
