Driver side window not working
Old Sep 30, 2005 | 09:16 PM
LRogers's Avatar
LRogers
Driver side window doesn't respond to the switch, the passenger side and the sun roof are OK. Any help or suggestions? The window does not drop the quarter inch or so when the door is opened. Thanks
Old Oct 1, 2005 | 03:30 AM
umberto's Avatar
umberto
That happened to my '04 MC last week for about an hour...now is fine. This has been talked about before..apparantly you can hit the inside if the door panel, in between the two speakers and it will work again...like Fonzie. I called the dealer and they confirmed about hitting the door panel or just closing the door hard...that's what I did I think. He told me it may just be one of those one time things, but if it happens again they'll replace the motor........but how do you tell if it is the motor, the regulator or the switch??
Old Oct 1, 2005 | 08:42 AM
supercharged's Avatar
supercharged
Hi LRogers
There was a write-up on motoringfile.com a little while ago regarding faulty window motors. The address is: http://www.motoringfile.com/2005/08/...ow_motor_issue
I hope this helps
SuperCharged
Old Oct 1, 2005 | 08:45 AM
LRogers's Avatar
LRogers
umberto, thanks for the information. When I drove to work this morning all was fine. I didn't close the door any differently than normal last night, I have made it a habit to close the door rather than "slamming it". Although that can be tempting at times. Just going to have to wait and see if it happens again.
Old Oct 1, 2005 | 02:53 PM
Alan's Avatar
Alan
Same symptom for my 03 Cooper S on the passenger side. MINI dealer replaced the motor.
Alan
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
messyjesse96
Aug 12, 2015 05:51 AM
atenzany62
Aug 9, 2015 05:54 PM
