Map light cluster buzzing
Old Oct 6, 2005 | 04:48 AM
yellow05mcs's Avatar
yellow05mcs
Am I just being picky? I have an 05 MCS, it's about a month old, and the plastic area above the rearview mirror that contains the map lights and the airbag light buzzes at low rpm's. Has anyone else had this, is this a fixable thing or am I crazy. Rattles and buzzes drive me crazy so to me it is amplified. Just wondering if this is normal for this car or out of the ordinary. and if there is a fix.
Old Oct 6, 2005 | 06:02 AM
Rev. Limiter's Avatar
Rev. Limiter
Troubleshoot your problem first. Take a wood toothpick and place it in the seam where the maplight cluster meets the header. If that doesn't "fix" your problem, then the buzzing is comming from somewhere else - the bulbs inside the cluster loose (you can tighten the mounts)? If it DOES "fix" the buzzing, cut a small sliver of the cloth side of Velcro and pack the seam. That will tighten it up, and won't be noticeable.
edit: Your header may look different from mine - I have a '05 MCSC with no airbag light...
Old Oct 9, 2005 | 05:20 PM
yellow05mcs
I will give it a try
Dec 23, 2015 10:36 AM
mdutton11
14
Oct 26, 2015 01:47 PM
oldkid6
Aug 11, 2015 08:13 PM
