Boost Gauge Install Q
Old Oct 2, 2005 | 08:48 AM
not-so-rednwhitecooper
ok, i have yet to get my gauge, but i have installed them before.
i cant seem to find a palce to tee off of. all the pictures ive found using search dont have a clear shot of anything, and it just seems to make it more confusing.
where doe they tee off for the factory gauge? Where have you tee-d off of for a guage?
:impatient
Old Oct 2, 2005 | 09:36 AM
Bahamabart's Avatar
Bahamabart
here is a pic from another thread. In this pic the intercooler and horn is removed making the job easy. You can do the install by simply removing the intercooler however IT IS REALLY REALLY TIGHT to work. The skin has finally grown back on my knuckles .
Once I disconnected the line from the engine, I cut it about an inch back from the factory nipple, added a RUBBER T (instead of hard plastic) which makes the job much easier.
Things that helped me A LOT
long needle nose like surgical clamp helped alot for it helped me reach the tubing once cut. AND I can stress enought the RUBBER T. I started with the hard plastic T like everyone else but then you need additional tubing to connect the lines to the T - either tubing or some type of connector. The rubber T was simple - slide in all three tubes (little soap/water). And beacuse its rubber it permits a lttle flex. My first attempt with a plastic T, once everything was back in place the connection point between the line and the T pinched a bit. THATS when I headed back to the car parts store and found the rubber T.
HOPE THIS HELPS
[img]file:///C:/DOCUME%7E1/BART/LOCALS%7E1/TEMP/moz-screenshot.jpg[/img]
Old Oct 2, 2005 | 09:39 AM
thanks, thats a much better pic.
what kind of rubber t was it?
have a part number from the box? ( i'm assuming it was just one of those from the HELP! asile or from one of the racks with the vaccum caps and etc tubing things)
Old Oct 2, 2005 | 10:13 AM
Bahamabart's Avatar
Bahamabart
I could kick myself because I can find the bag with the part number. I even went back to the store to buy another one for a freind but they had only one. It was made by accu-tite (sp?) and its black. I have never seen another. And yes in the asile/rack along side all of the other T connectors.
ITS worth hunting for ! Really made things easier.
Old Oct 2, 2005 | 02:19 PM
ok, i'll take a look.
i have to see under the hood of my friends GTI and see how we did it on that one.
i think we used a brass junction black with the crush fitting for the nylon on one of the trr's and 2 of the rubber tubing connectors with the ribs on either end.
all in all, i got a very nice autometer gauge and pod today and i hope to have it all runing asap!
Old Oct 2, 2005 | 04:18 PM
ok, i got it in
problemo!
its only reading VAC, at about 5 grand it only hits 0 +/- and it wont go past. its reading about -20 vac at an idle. whats going on here?
Old Oct 2, 2005 | 04:48 PM
ignore me, i'm an ignorant moron, i had it hooked up to a regular vaccum line.
problem solved, now i have to reassembe the entire thing i tore apart! :impatient
Old Oct 2, 2005 | 06:33 PM
yay, got it all working!
Old Oct 2, 2005 | 11:24 PM
daflake's Avatar
daflake
Next project, clean the garage!
Glad you got it working...
Old Oct 3, 2005 | 09:40 AM
clean what? i just cleaned it!
Old Oct 3, 2005 | 11:51 AM
simpsoap's Avatar
simpsoap
mount..
the mount you used for your gauge on the pillar, did that come with the autometer gauge or was that purchased seperately? Which style Autometer gauge did you end up choosing?
Old Oct 3, 2005 | 02:23 PM
its just a black autometer 2 1/16th pod, 14 bucks at summit
i got a pro comp ultralite 20 psi vac/boost gauge, 54 dollars.
Old Oct 4, 2005 | 07:18 AM
simpsoap's Avatar
simpsoap
I think the gauge looks really good mounted there, were exactly are you located in Ohio, I am located in Springfield, OH.
Old Oct 4, 2005 | 07:20 AM
Springfield, eh? you have a nice antique museum down there!
i'm waaay up north about 30 miles east of cleveland. I'm actually right down the street from Classic.
silence2-38554
98
Sep 21, 2016 02:52 PM
wkp1219
Nov 13, 2015 07:52 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
