Clack when accel. and Double clack when decel.
Old Sep 29, 2005 | 08:27 AM
tradiuz's Avatar
tradiuz
MTH Specialist
Heres a brain teaser for you guys.
My 05 MC makes a clack noise when starting out (seperate from the ABS/Locking, since this happens at 0-5, and the other two happen at 11mph). Clack = two billiard ***** hitting.
When decellerating, sometimes, it makes a double clack.
Its at the service dept now, for maintenance and looking into this, but I wanted to know what you guys thought the problem might be?
Old Sep 29, 2005 | 08:47 AM
go_mini_go's Avatar
go_mini_go
Check out the "what makes a MINI click" thread, may be the same issue.
Also, I had my tool kit stowed next to the battery, it make a thunk sound as it moved around back there. I now store it on a shelf in the garage, not going to be much help with out a jack and spare anyway.
Old Sep 29, 2005 | 09:46 AM
ahamos's Avatar
ahamos
Coordinator :: River City Minis
Do you have an aftermarket front sway bar or end links?
Old Sep 29, 2005 | 10:52 AM
tradiuz's Avatar
tradiuz
MTH Specialist
Car is stock except for MTH, aero grill, and amp/sub. It isnt the sub box moving since it would make an entirely different noise (more of a dull thud than a clack.)
Also, on the accel clack, the car semi-stumbles too.
Old Sep 29, 2005 | 07:57 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Hmmm, they're saying that the clack noise is normal... a charactaristic of the Getrag... and they found that the Clutch might be glazed over cause its making a sound like a whale call (?)... Any idea what they mean by that. They didnt mention how much its going to cost but I'm gonna call tomorrow to make sure I dont get slammed with a $1k+ bill on my first dealer service at 9k.
Old Sep 30, 2005 | 07:46 AM
danielg's Avatar
danielg
AHH!
This is your problem: https://www.northamericanmotoring.co...ad.php?t=44291
It happend to me a few weeks ago. You're welcome to read the entire thread, but the first post will give you the fix. I took my MINI to the dealer; the service guy just did steps 8 and 9:
8) Re-torque nut to 134 ft-lbs.
9) Tap lip of the axle-nut back into the indentation to lock it in place. Again...use a brass drift punch to make sure you don't damage
Old Sep 30, 2005 | 08:12 AM
tradiuz's Avatar
tradiuz
MTH Specialist
I looked through that thead, but it isnt a constant noise, its a only once noise. Clutch being replaced under warranty!
Old Sep 30, 2005 | 08:36 AM
danielg's Avatar
danielg
Only once ever, or only once per start, speed up, or slow down?
Old Sep 30, 2005 | 08:56 AM
tradiuz's Avatar
tradiuz
MTH Specialist
Only from a dead stop accel, it would make the noise once, then nothing. The double-clack noise was when decellerating to a stop (or less than 5mph), and comes form the back (i think its the rear brakes or something... its odd to say the least).
Old Sep 30, 2005 | 08:58 AM
Cooper_Si's Avatar
Cooper_Si
Mine had the "Whale Call" Good way of explaining the noise
Only ever did it from cold, and when you pulled away in first gear....like a woooooo noise !
And that was on a 02 plate Cooper S with 18,000 miles, clutch replaced and noise went away. They did do the release bearing first but noise were still there
Old Sep 30, 2005 | 09:04 AM
danielg's Avatar
danielg
My noise happend only once, too. During accelerating of the wheel, i.e. starting, slowing quickly.
Two pool ***** hitting is the best way to describe the noise I heard. Have someone stand outside the car, is it coming from the wheel area?
Old Sep 30, 2005 | 10:03 AM
tradiuz's Avatar
tradiuz
MTH Specialist
I'll have to check that. It feels like its coming from under the driver floor board though, and you can feel it as well as hear it.
Old Sep 30, 2005 | 12:37 PM
glassintrepid's Avatar
glassintrepid
I have the Whale call too. But i have a few mods like pulley, intake, exhaust, software. Do you think they would deny my clutch replacement because of them? Please dont give me any garbage about how i should not have modded. Car has 35500. Should i try to do it before the 36000 miles?
Old Sep 30, 2005 | 12:38 PM
glassintrepid
I also have the clicking noise.
Old Sep 30, 2005 | 01:45 PM
tradiuz's Avatar
tradiuz
MTH Specialist
If you wait until after 36000, you're out of luck. Get it there ASAP, as the clutch is a wear and tear item (unless you have a faulty part ruin it.. flywheel/TO Bearing). Its my understanding you're most likely to get it covered free between 30k-36k since its usually considered abuse pre-30k.
I dont see how they could deny your clutch claim on account of other mods, unless they attribute the extra stress on the clutch due to the extra power you're putting down due to said mods. Take it in. The worst they can do is tell you no, and then ask for their manager...
Old Sep 30, 2005 | 06:44 PM
apexer's Avatar
apexer
My noise is also coming from under the floor-board. My guess at this point is the steering rack. I had dealer tighten the rack at first service & it seemed OK for about 200 miles then came back.
Old Sep 30, 2005 | 08:59 PM
glassintrepid
Called Heather this afternoon, do you know if she is back yet?
Old Oct 1, 2005 | 05:58 AM
tradiuz's Avatar
tradiuz
MTH Specialist
I used MoMoney. MoTW is waaaaay too far away.
Old Oct 2, 2005 | 05:38 PM
ahamos's Avatar
ahamos
RedBaronF2001 and I have both isolated a very similar-sounding issue to being the brake pads. When the car is at rest, the pads are in contact with the rotors. If they're hot, they tend to very slightly fuse to the rotor. When you move, they either shift just a tiny bit or break their spot-weld. It does sound just like two pool ***** clacking. I would also expect this sound on a car with caliper stiffeners.
Old Oct 2, 2005 | 06:27 PM
pcnorton's Avatar
pcnorton
Two Billiard ***** in the trunk?
CV Joint ?
Loose calipers?
Paul
Old Oct 2, 2005 | 08:48 PM
VoiD's Avatar
VoiD
I heard it could happen to some two piece wheels coming apart...
Old Dec 1, 2005 | 09:59 AM
mcs2nr's Avatar
mcs2nr
ii have been reading the same thing about 2 pc wheels, but my noise is loud as hell......has anyone determin what causes this anoying noise, my wife already hates me for buying this car, and now its making it worst, i hate to here I TOLD YOU SO...i have a 1974 mini cooper S and i expect that type of thing with that car, but not something that is brand new....
Doc Pain
Mar 10, 2021 04:50 AM
SJ-R50
Oct 28, 2015 08:39 AM
donniedarko
Sep 29, 2015 01:16 PM
Puggles
R60/R61 Stock Problems/Issues
Sep 11, 2015 11:53 AM
Filmy
Sep 6, 2015 10:06 PM
