I threw a belt, HELP!
Old Nov 5, 2005 | 11:29 PM
SpiderX's Avatar
SpiderX
I have a 19%...... I threw a belt tonight and I want to go to the Atlanta Minis event tomorrow at 1:00. Can I get a belt at Pep Boys? what size? is there any directions as to how to put it on as I have not done this before?
Old Nov 6, 2005 | 05:07 AM
SpiderX's Avatar
SpiderX
Bump.......it's Sunday morning
Old Nov 6, 2005 | 06:01 AM
K4KAS's Avatar
K4KAS
Couple posts down from this one may have info you can use.
https://www.northamericanmotoring.co...ad.php?t=43383
EDIT: Sorry,looks like you already found it!
Old Nov 6, 2005 | 06:23 AM
IsItElectric?'s Avatar
IsItElectric?
How-to
You probably already know about this, but...
http://store.webbmotorsports.com/for...topic.php?t=17
A helpful guide on how to do the pulley replacement. Although it's almost 9:30AM now...
Good luck!
Old Nov 6, 2005 | 09:41 AM
k-huevo's Avatar
k-huevo
You need the belt tensioner tool to move the tensioner arm while you place something (nail, hanger wire, awl) in the spring strap hole to secure the arm out of the way. To make the job easier remove the lower air dam and skid plate; even easier also remove the bumper cover, passenger side tire and wheel well lining.
Without having the tensioner tool I’ve used a metal stake with a mushroomed head on a floor jack and have also used as a lever a piece of angular metal used to mount conduit to walls.
Since you should be changing the belt regularly with the 19% it’s time to get the right tool. The tool should be reinforced with a weld to avoid bending.
Spider X as many times as it has been necessary to ask for directions on some kind of trouble shoot issue; don’t you think it is time to get a Bentley service manual? Please don’t take offence because none is intended; I enjoy your openly shared experiences:smile:.
VanisleRyan
Sep 30, 2015 08:35 PM
eliseo1981
Sep 30, 2015 07:57 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
