bad brakes
Old Oct 11, 2005 | 01:39 PM
dan cooper scooper's Avatar
dan cooper scooper
bad brakes
Brakes in yellow mini is really bad .. have to pump it a few times before the car stops .... otherwise, it would look like a pancake! haha ... any idea?
Old Oct 11, 2005 | 01:46 PM
OctaneGuy's Avatar
OctaneGuy
Shouldn't have to pump brakes. If you hold it down, ABS will activate and will pump for you.
Old Oct 11, 2005 | 03:19 PM
namwob's Avatar
namwob
Is the pedal low before pumping? Are you still under warranty? More info. would help us help you. Ok its a classic mini. You may need to adjust the rear brakes. Check under rear wheel cylinder boots for fluid. Check boot under brake pedal where master cylinder comes through. Do you work on your own cars? If not take it to a shop.
Old Oct 11, 2005 | 03:41 PM
namwob's Avatar
namwob
Beneath the bonnet is for the new Mini ( hense Octane Guys ABS remark & my initial confusion) Look under forums; there is a section called classic mini talk.
sevin
May 2, 2026 06:11 AM
woodstudio
Mar 15, 2020 08:28 AM
HaveATank
Sep 4, 2015 08:04 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 25, 2015 09:18 AM
