- Whining noise = Dead Battery
- Window "ratchet" sound
- Ground location for IHKA (climate control) servo motors?
- Where to buy oil filters online?
- Control arms little loose?
- tranny exchange?
- Brake Light woes??? a v39 stalling?
- Burning Plastic Smell?
- fan blowing
- hybrid mini possble?
- Xenon vs. non-xenon (mechanically)
- High pitched squeal from fan????
- 05 JCW kit - got scamed, momentarily
- K & N Filter
- Does Anyone Know What "Internal DKE Motor Failure" Means ???
- Remanufactured parts under warranty??
- Clutch slave cylinder failure
- Posessed speedometer needle!
- MINI mechanic?
- Xenon ballast loose
- Having difficulty getting in & out of gear
- Yes, another "Service Engine Soon light" question...
- Fan/blower not operating - input sought
- Idling Noise
- HELP!! Brake lights not working
- Nearing my wits end...
- Alignment/Tracking problem??
- Rear O2 sensor code: Service Engine Soon light
- Alta Intercooler warning ....
- RPM drop problem
- California Gas ?
- Myster muffler part?
- Mini Mania Venturi Hood Scoop?
- SRS Reset Light Tool (Scanner???)
- Boost gauge install?
- 50K Warrenty Check list
- MTH PROBLEM...please help!
- Claim that not going to v39 may void warranty?
- thrown code and car crapping out
- Rats under the bonnet!
- Electrical Gremlin?
- Simple OBD Scanner
- Clutch Pedal Advice/Help Please
- New BMW/PSA Engine?
- Brake pad help?
- Drivetrain noise...
- Slight whirring noise from console?
- Brake lights on after engine is off
- clutch pedal
- 38 or 39.2
- HELP!I DROPPED A SOCKET into the engine bay where the fan is.
- Anyone know the exhaust diameter for 05
- brake pad sensor accuracy?
- Denso IK22 with stock wires?
- Oil Filter and Oil?
- Need Help Fast
- Wonky Headlight...
- Looking for a portable dehumidifier for garage
- Radiator and Cooling System
- Question on the 'S' engine internals
- ? Changing Anti Freeze
- Mini on the scales... what's your Mini weigh?
- GIAC ECU flash question for you...
- Burning Clutch smell
- Filter for MC ProMini Intake
- inHg conversion to psi question
- Vibration in the gas peddle
- Squeeking when rolling from stop
- Sticky Gearshift
- Bad Gas Mileage on MC after upgraded software?
- Air bag light went on!!!
- Head Lights different colors???
- Serv. Engine light turned on - 05 MCS
- Older exhaust on an '04 Cooper S?
- How to access front fog light cavity?
- Window failure fix free!
- I couldn't get the oil filter canister off
- 1400 Mile Breakin?
- Starting the engine
- Does 2004 MCS come with the skidplate?
- Cruise Control light flashing, no workie
- Went through my oil before 10k
- Mobil 1 will invalidate my warranty...WTF?
- Starter Button
- How Bad Is It To Continue Driving With The SERVICE ENGINE SOON Light On?
- Rear Clunk Sound...
- Fuel system cleaner/treatment
- So just how good is the 2005 MCS exhaust?
- Gearbox hollow noise
- no crank - no start intermittent problem
- clutch, lifespan?
- Software upgraded to 39.2 issues on MCS
- Cracked Headlamp Ring
- A Question for you Technophiles
- '05 and the Yo-Yo
- First Service
- CVT shudder at "abrupt" stops or "stop-n-go" maneuvers
- Coolant overflow tank cap leaking
- Three Annoying Issues
- Major CVT Lag
- Fog lights & driving lights...
- Xenon Short Circuit?
- my MCS keeps shutting down.
- Looks like I have a sulfated battery...
- Boost Pressure Question
- 3 small bolts......
- Which Spark Plugs?!
- Spark plug wires
- how many times have you brought your car in for the same problem.
- Dealer says Mods are causing service engine light to come on
- fan locked on
- Does the Mini use narrow or wideband?
- How Long Does it Take For Engine Cool down to comfortably be able to change the oil?
- spin on oil conversion from Moss
- oil filter location
- Headlight washers ?
- How do you tell if your supercharger has worn out?
- Window fogging!!!
- Gas Gauge Issues
- "Driveability Recall"
- DSC, ABS, Flat Tyre Lights on HELP
- Help! Clutch Noise
- Spark Plug Wire Question
- Air Intake temp on the Cooper
- Oil Change
- key wont go in
- Blew my Engine
- High RPM....
- Clutch Smell
- Good old vibrating vacuum hose issue
- Broken Trim/window re-set
- Vacume line help... again
- Magnuson-Moss Act
- Help with first time DIY oil change
- Rattlling sound until I put the clutch in...
- Electricals
- Strut Brace How To?
- Stroker
- Rotor Rust and a Computer Glitch
- Squeaky windows
- Installed my Pilo intake and Webb intake mod... but.. problem!
- Pictures of rear control arm on car?
- torque-nique
- High Beam/Low Beam Uneven
- whine at idle but disappears with engine accel
- Very Bad mileage!
- Ryephix2 Bypass Valve Spring Upgrade
- MINI Recalls
- What oil should I use??
- Ordering Parts
- Bumper damage
- Visual Evidence of Coolant Reservoir Problem?
- Need tools for the MINI?
- Shimmy in my mini
- Reduction pulleys and the companies that offer warranties that sell/install them
- Redline Water Wetter...
- Any problems with the Ryephix?
- P1689 error?
- Harmonic Balancer / Belt Tensioner damaged MCS '04
- 4th Fuel Pump In 2 Weeks!
- 10k mile service?
- Part to fix speaker rattle
- Clutch gone at 20,000 miles
- Pulley Tensioner
- V.39 and loss in gas mileage and hp
- recalls
- Exhaust rattle- Great Stratosphere svc
- Pipercross Intake
- How to make the OEM fog lights ACTUALLY light up the road
- Can You ID this???
- My right Xenon went out
- Mixing Dot 3 with Dot 4
- First Oil Change...
- Help!!! Dripping Mirror
- removing sparay paint
- Steering click....help needed.
- speedometer off?
- Wtf?
- Skid plate - which way is up?
- When will my '04 MCS start for the 1st time?
- Adjusting the "miles to service" reading
- Detonation – please HELP diagnosing cause
- power stearing probs
- New Mini owner looking for Info
- Brown Coolant?
- Foglights and Xenon Headlight Question
- Mini Cooper Turbo Kit on Ebay
- service engine light - what does it all mean???
- Service Costs
- service engine soon light
- DSC and Runflat indicator
- Radiator Fan won't turn off!
- Rod rap on cold start
- Jacking the Mini safely
- Coolant change - refill
- not so hot seats.
- California drivers w/ mods....
- 1 or 2 stripes?
- B.S. detection needed
- Changing Your Oil
- Weird Clacking Sound
- heat shield rattle
- Octane Boost
- please identify this engine noise.
- 28,000 mile service
- Grinding Reverse
- Pyrotechnics in the Mini
- MCS Battery Smell?
- 05 MCS Oil Dip Stick
- Persistent A/C Problems...
- MCS auto. transmission news?
- Help! Headlight bulb replacement
- throttle responce
- Major help needed for my Oil Filter housing
- Got v38, A/C died
- oscillating idle
- Question???
- Did the dealer change my software?
- Short Shift?
- 15K oil change interval
- Car smell after running really hard?
- 2005 MCS Exhaust Problems
- HELP...PVC hose routing
- My Shifter has become hard to shift
- help with panel
- Low mileage problems?
- Second oil change: Analysis Results
- Two types of oil filters?
- Polished Intercooler And Piping
- Gearing
- Bently Manual Review
- Non auto-ac AC question
- HVAC problem
- No rev limiter?
- yet another gas milage thread....
- Almost failed Pa emissions
- tire pressure light keeps flashing
- MCS Fault Code Meaning
- Is it Difficult to Repair the CVT Transmission?
- Windshield wipers acting up!!!
- DSC or LSD in the Northeast?
- Clunk feel in steering wheel??
- Transmission Woes
- smoke coming out of scoop
- MFSW left center switch?
- Squealing windows
- Broken Electric Window
- Is power steering not working right?
- Post Dealer Oil Change Issues
- Trouble removing filter canister?
