High Beam/Low Beam Uneven
I have the standard halogen headlights and I can't level both high and low independently, so do I find a happy medium or just level the low beams since they'll be used primarily. Does anyone else have this problem? It's the right side that is low on the high beams, is this normal? When I adjust the right lamp up, then it's the low beam that is too high. I checked all the bulbs and they are all the way in correctly and straight.
I'd adjust the lows evenly and not worry a lot about the highs. If the right's a little higher, it'll just help light up that side of the road to help you see anything that might be there (pedestrians, animals, etc....)better.
vbmike
Oct 15, 2015 04:32 AM
Sep 3, 2015 10:29 AM
