MCS Battery Smell?
MCS Battery Smell?
Anyone with a Cooper S ever go into the boot (trunk) and lift up the floor panel to look at the battery? Last time I did this, I got a strong whiff of sulphuric acid. This is quite normal for a lead/acid battery to give off, but what's of concern is that on the MCS, these vapours are released inside the car instead of the engine bay. Though I've never detected them from the driver's seat, I'm sure they are present and measurable in the air. Sulphuric acid is, I believe, a known cause of male infertility...
Mike.
Mike.
Mike.
Mike.
I guess it's to reduce the chances of us having kids to put in the tiny rear seat
Originally Posted by El Diablito Rojo-N20Mini
sounds much better than a vasectomy..... where can I sign up????
Originally Posted by kenchan
In my case, it didn't work. My wife's 2cm tonight.
any day now
for Mini-Kenchan.
oh btw, no, when i lifted the trunk floor, my battery did not have any
smell.
any day nowfor Mini-Kenchan.
smell.
battery
As I recall mine has a "drip tube" like a motorcycle battery that leads out of the battery box.
If you are Charging or discharging the battery at a high enough rate to cause Acid fumes in the battery box, you should investigate why.
JD
JD
