PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. 05 super charger on a 03 ?
  2. electric waterpump or s/c rebuild?
  3. Chrome Hatch Latch thing replaced with Black one?
  4. Squeaky door
  5. Could someone post pictures or diagram of air hose locations?
  6. Detroit Tuned Bypass Valve vs Stock Bypass Valve
  7. need rear window clips
  8. Drivers Window Leaking Issues!!!
  9. MCS Engine Rebuild
  10. Bad Gas Cap
  11. Low Speed Fan Resistor - we need solution
  12. Windshield cracked I heard PPG is good, but where?
  13. Power steering pump vs. Fan
  14. Rebuilding the brake caliper
  15. Front end noise and dealer related issues
  16. OBD p1776 1776
  17. Chirp when leaving from a dead stop
  18. Help Please - Limp Mode starts when I run the A/C - obd = p1688
  19. OBDII code P1688 - limp mode when air conditioning is turned on
  20. ABS and Traction control light?
  21. Metal squeaking in gear box when getting on first gear???
  22. Great, now a misfire..
  23. CHECK THIS OUT: Crank Pulley gone bad
  24. replaced battery now remotes dont work
  25. Xenon Headlight Problem
  26. Driver-side Front Wheel Noise
  27. Driver side brake pad wearing faster than other side?
  28. "Hesitation" at 3000rpm/70mph
  29. Help! Front brake line blew and oem part not available
  30. a/c repair shock
  31. Survey: Crank Pulley Failures
  32. Strange Engine noise
  33. OEM Ride Height and Hood Gap?
  34. Bleeding Brake & Clutch systems
  35. 2xx miles over warranty + Coolant leak
  36. Here's a weird one...
  37. ATTN.: ALL BBK OWNERS
  38. transmission question
  39. Vibration on driver side window
  40. Hesitation
  41. Is there a body module avaliable from someone besides Mini dealer?
  42. ABS DSC warning lights on
  43. Location of 2008 S body module
  44. Belt Tensioner Rattling...
  45. weight sensor air bag trouble
  46. Replacing 3rd brake light
  47. HELP!!!
  48. Transmission Fluid
  49. Rattling Coming from Passenger Side of Motor...
  50. windshield crack
  51. A1 Cardone PS Pump
  52. what is it and how do i remove it?
  53. PCV valve hell
  54. A/C blower motor
  55. Step by Step How To on Replacing Radiator Fan..
  56. Window Operation not smooth.
  57. Lights on speedo turning on and off
  58. Loose Hood Scoop???
  59. Pag Oil for AC, what viscosity? How to add?
  60. How to program key fob
  61. Dent on hood :(
  62. Weird turning noise :S
  63. Lug Nuts or Studs?
  64. Noise when shifting from 1st to 2nd
  65. Brake warning light but..
  66. CVT transmission woe$
  67. HELP!! Mini Starting Problems
  68. Surging, SC whine, p1242, p1109, red hot exhaust manifold
  69. My first speeding ticket
  70. Xenon healight lens Cracked
  71. Locating Mini Mechanics MA/NH
  72. No Air Conditioning - AC Light blinks when turned on?
  73. Paddle shifter broken
  74. New radiator fan check
  75. Power steering failure - Fan is not moving
  76. HELP - Brakes are off and...
  77. Changed wheels on 2006 Mini now have seat belt light, airbag light, + no dash lights
  78. Steering + rad. fan issue
  79. Loss of power & fuel economy. Fuel pump bad?
  80. Coolant top off normal?
  81. Need help with this code P0646
  82. dsc light is on
  83. HOSE FROM BRAKE RESERVIOR TO CLUTCH MASTER CYLINDER?
  84. Sun Visor
  85. Coincidence???
  86. Noise / ticking from transmission
  87. URGENT PROBLEM: MINI dies with no apparent reason!
  88. HELP! Engine died in parking lot. No check engine light
  89. Knocking sound when accelerating and decelerating
  90. Better MINI Service Department?
  91. MCS transmission trouble
  92. Dead MINI!?
  93. How to generate "V39.0 Diagnosis report"?
  94. Question: OEM Front Rotors from non-Mimi vendors
  95. Brake Master Cylinder
  96. Doing brakes for first time myself - need advice
  97. P1125
  98. Transmission Whine In 4th Gear [06 MCS]
  99. how to tell if belt breaks on cvt transmission?
  100. Engine whine related to AC???
  101. Cruise control out--specific questions
  102. Different size sparkplugs for various years?
  103. Recent Long Beach Mini Service experiences??
  104. Pulsating noise when turning right
  105. Tough question: shaking steering wheel, not wheel balance issue
  106. No coolant in reservoir
  107. Chirping coming from wheels
  108. car dies coming to a stop only w AC on and high outside temps
  109. Clutch? Please Help?!
  110. Excessive crankcase pressure?
  111. Broken seat - I have to motor alone
  112. Tie Rod Ends, 03 vs. 05?
  113. 2004 MINI Cooper EML, oil, & battery light
  114. Vacuum hose to bypass valve
  115. Cigarette Lighter fuse blown twice
  116. Something is killing my ballast
  117. Switch bank gone bad ?
  118. Dent Dr removed door pannel, now the door wont open from inside!
  119. Help-Brake job gone awry.
  120. Clutch Replacement Pittsburgh PA?
  121. Hiccup at 3000ish RPM... where to start diagnosis?
  122. Are MC and MCS dipsticks interchangeable?
  123. RPM related whining and high pitch rattle
  124. Air conditioning hose failed
  125. How to replace headlight washers?
  126. Paint job crisis (please help)
  127. Broken plastic glove box latch
  128. Battery exploded!
  129. HELP! Suggested Non-Dealer Service in Jacksonville, FL
  130. Left side lights not working
  131. Car won't turn over when hot
  132. Crack in valve cover!
  133. Convertible top will not close
  134. Any idea what this is?
  135. Door lock actuator part# help
  136. MCS slave cylinder help
  137. Door lock and power window problems. (the third time now)
  138. Random E-Brake Light = No Windshield Wipers???
  139. Lost ignition key
  140. Gas Tank won't unlock
  141. Clutch failure cause or effect!
  142. '03 MCS Engine Parts Cost???
  143. 2006 R53 Water Drop under engine. Newbie planning a long trip.
  144. OBD2 Connector Pin 16 missing 12v
  145. Air Conditioning Additive/Intake Vents
  146. Where did my 2psi of boost go?
  147. another day, another A/C issue on NAM
  148. huge battery problem!!please help
  149. weird knocking when idle
  150. Engine stumble, a different type
  151. Bad Bad Day thanks to my MINI! Advice Needed!
  152. How to fill refrigerants, R134a
  153. Any one used Supercharger Technologies for repair?
  154. Tick Tock Knock sound - Drivetrain? - 2004 MC Auto
  155. Overheating help
  156. Body Control Module
  157. 05-S 6 speed transmission shifts hard intermittently
  158. Broken supercharger
  159. Grinding noise when hard turning from stop, help!
  160. Car wont start.
  161. Strange fix for stuck radiator Fan
  162. hesitation/loss of power in second? Still?
  163. Clutch Slipping? No noises. Upgrades?
  164. Exhaust broke at the cat! Help!
  165. Most weight in Mini Cooper.
  166. Steering knuckle pinch..
  167. Which is most likely to leak, PS pump or hoses?
  168. Friday Brain Buster
  169. Power Steering Fan
  170. Interior Cabin Lights Issue
  171. Leaking Windshield Washers?
  172. CVT tranny on the brink....possible solution
  173. Clutch Getting Hot- Overheating Quickly
  174. Goofy MINI Cooper issues...
  175. Loud 'clunk' if 3000 rpms not reached before shifting gears...!
  176. Dies on cold start up
  177. Oil Filter Housing Problem
  178. How to reset tire pressure light on 06 MCS?
  179. MINI some times does not want to start
  180. Warranty Question - Need Counsul
  181. Erratic temp gauge
  182. Will This Bumper Fit My '07 MCSC?
  183. Throw-out bearing?
  184. ABS/ASC/DSC codes that won't clear
  185. Power steering fluid tank leak around cap?
  186. Hot Engine-Impending Doom or Paranoia?
  187. Oil housing cap cracked
  188. The Dreaded Wheel Sensor-How to Fix it.
  189. Weird Knocking Sound
  190. 2003 MCS: Fog light burned out, finally...
  191. Front cigarette power doesn't shut off anymore
  192. Help- poor acceleration
  193. Pelican Parts - Cabin Filter
  194. Stuck gears
  195. Loose plastic trim on leatherette seats
  196. Thermostat gasket only?????
  197. Wont accelerate over 4000rpm
  198. Systems gone crazy
  199. Seat Belt Problem - File a NHTSA complaint
  200. Engine died at idle
  201. how to remove ebrake console?
  202. My MINI is mad. Electrical problem.
  203. Seat heater is not working???
  204. Advice request: Serpentine belt replacement
  205. Clutch pedal suddenly grabs high
  206. Pictures fired seat belt
  207. petrol
  208. Burns quart of oil every 1000 miles
  209. DME issues
  210. Sun Roof Stuck
  211. Bad valve spring
  212. Huge play in Steering wheel
  213. Cold exhaust rattle
  214. Air conditioner only blows cold air on passenger side
  215. Open can of ATE brake fluid - can I use?
  216. A/C nonfunctioning
  217. Fog light repair
  218. Need brake diagnosis please
  219. Proper grease for the sunroof?
  220. Issues with Radio,A/C,Nav, interior lights
  221. speed ?
  222. Glove box will not open
  223. Freeway kill
  224. Rough downshifting in automatic MCS?
  225. AC not blowing cold
  226. Aircon bump
  227. Trying to clear codes on ECU using scangauge II
  228. Getrag transmission parts available???
  229. ALIGNMENT????
  230. Alta CAi issue
  231. Power Steering Fluid Flush?
  232. Can't remove headlight bulb on '05 MC. Help!
  233. What to look for
  234. Engine Code P2402 Anyone????
  235. Talk about GREAT timing!!!
  236. I'm all wet... It's raining inside my '03 MCS
  237. seatbelt squeak
  238. 2003 Cooper CEL Problem
  239. Cooper S xenon headlight problems
  240. Leather Seat problem
  241. EML / Check Engine / DSL Lights
  242. Why doesn't my back-up light work?
  243. Crush washer for oil drain plug?
  244. Accident on day 1, please help!
  245. Clutch slave cylinder bleeding snafu
  246. An other door lock problem... trunk can't lock.. how to do it manually??
  247. is there a way to manually roll up the window
  248. Any tricks to get the #%$@# oil canister off?
  249. How to remove passenger side drive axle?
  250. How to Replace Radiator Fan assembly?
