Crack in valve cover!
Old Jul 5, 2009 | 06:50 AM
pizmo pete's Avatar
pizmo pete
Hey all, While installing a MSD ignition pack the new bolts somehow cracked the cover and now leaking. Called the Stealer and it's 280 for the cover and 25 for gaskets. Can I patch the crack to hold me over till new cover comes in? I tried 2 stage industrial epoxy the grey stuff and ran a patch over the crack. I let it dry 24 hrs hard as a rock no leaks at idle...Having read about valve cover explosions.....how much pressure is the cover under? Is the patch safe? if the pressure is low I cant see the epoxy failing....also any body go a USED cover for a 2002 MCS?
Old Jul 5, 2009 | 08:11 AM
cartar452's Avatar
cartar452
JB Weld it from the inside. That will be fine until you can get a new cover.
Old Jul 5, 2009 | 08:47 AM
Thumper460's Avatar
Thumper460
Shoot me a PM if you wish... I have a few valve covers!!
Just a thought..
Thumper
Old Jul 5, 2009 | 01:21 PM
pizmo pete's Avatar
pizmo pete
Thanks guys the epoxy seems to be holding I think the bond was good. Thanks for the offer thumper! Sent you a PM....
09R56
Nov 16, 2022 10:49 AM
schwac2
Sep 11, 2015 11:13 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
