huge battery problem!!please help
so i thought my battery was dead so bought a new battery 2 days ago, however i went to work and my car wont start this time not even a light goes on.i have no idea waht could be wrong. please help cause a new batery cant just die in two days . thaks
ashley
ashley
My first thought is, is it possible your alternator died? I'm thinking that it's not charging the battery, and I do believe it is possible for the battery to run for a couple of days with no charging.
jump it and go to a local parts store, leave car running, and ask them to check your charging system. If it's charging then you may have a short somewhere and I'd start with looking at any aftermarket wiring, lights/radio mods and such, then the Power Steering pump and radiator fan.
i found out what it was,it was a bad ground wire, i have no idea how it came loose but it was not the one attached to the battery terminal it was under the battery(somewhere down thier). how wired is that. ohh well now i know. thank you all
now all i have to do is fix my abs light.
ashley
ashley
LordOfTheFlies
Oct 19, 2015 05:02 PM
Lschneider
Aug 21, 2015 02:21 AM
