PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. What are the causes of a "hard start" when cold?
  2. Knocking/tapping sound at idle
  3. Please help- new clutch needed
  4. Optima battery for Cooper?
  5. New transmission?!!
  6. Cleaning intake ...
  7. Battery Recall?
  8. Pulley Just Woke Car Up!
  9. fabric stuff
  10. 2004 Mini engine not running right
  11. '06 remote key stopped working/programming
  12. Window Help Needed
  13. Failed CVT in the desert..
  14. Uh-Oh.... What could I have done?
  15. Stupid Shift . . .
  16. spark plug recommendation
  17. My gf 02 MCS won't start
  18. I need to Vent too (dealer problems)
  19. JCW Intake Intall questions
  20. HOT in the wrong Places
  21. Removing rear bumper?
  22. brake reservior cap size-brake bleeder.
  23. slow to start
  24. Location of gormmet through firewall
  25. Good MINI Repair place in Philly?
  26. I can finally say...
  27. A/F Gauge wiring
  28. Sun Roof Drain Tube
  29. anyone with 05s have these problems?
  30. The New E-10 gas... are you having issues with it?..
  31. DIY Changing Coolant...Anyone?
  32. Did some remodeling
  33. Geez!!! I got flashed this afternoon!!!
  34. Help Help . Check Engine Light
  35. Clutch pedal spring
  36. Clutch Howl???
  37. Removing Front Bumper?
  38. ECU problem part 2
  39. So I got the S on a Dyno today.......
  40. Anyone with Bentley Service Manual?
  41. '04 Cooper S Wiring Harness Diagram
  42. Driveshaft Parts Inquiry
  43. Idle vibrations
  44. coolant temp sensor location
  45. How to calibrate steering angle sensor?
  46. Jet Engine under the hood? Or maybe just a really loud fan?
  47. A/ clutch
  48. Supercharger/Manifold gasket leak
  49. Rust - filing a complaint with NHSTA campaign
  50. Auto AC setting - 2 degree increments?
  51. Intake plastic
  52. Hot Track Day-Indicators Lights went on
  53. Brake Sensors?
  54. Pop - Clunk Clunk!
  55. Part No. 61.13 6 914 209 - 01 ??
  56. 2003 Cooper S Overheating Problems?
  57. Abs Fuse Tsb??? Show Me!
  58. Two issues
  59. Best SC Pulley Removal Tool
  60. Air Conditioning noise
  61. A/C weak/temp
  62. Power failure while driving
  63. Pure Power Lifetime Oil Filter ?
  64. Service Engine, DSC & Battery Lights - No Power Steering - Bad Alternator???
  65. Engine won't turn on first start!
  66. Stick shifting technique
  67. Cutsom CAI Box project
  68. Clutch acting weird... What's wrong?
  69. Mystery: whirring noise beneath rear seat
  70. M7 Thermostat
  71. Clunking from driver side front.
  72. Pilar cover
  73. Using a floor jack to assist with tire rotation
  74. fog light seperating from bumper
  75. 04 CVT wont start
  76. Modding an 05 MCS Auto Transmission
  77. flywheel weights
  78. Clutch slave cylinder gone after 21k
  79. LSD and ruff rutty roads?
  80. Check Engine light
  81. Auto lock not working
  82. Couple of issues with my MC CVT ...
  83. Oil catch can, How To Make Your Own.
  84. Ses/eml
  85. Fact or Fiction: Oxygen Sensor Failure
  86. Healthy Mini again
  87. Getting to the buzz
  88. M7 Oil Catch can help
  89. Problem A-brewin in Transmision Town
  90. SES light on at 9100 miles - Any ideas?
  91. 15 Things My 2003 Needs Fixed at 49K!
  92. Vibration
  93. what do these lights mean?
  94. Oil Drain Plug Location??
  95. Help taking dash apart to access defrost air vents
  96. Always replace filter with Oil? why?
  97. Preventative maintenance
  98. New S - Break in exhaust note change?
  99. herky jerky big whir very rough idle
  100. Supercharger differences
  101. Oil Filter Housing - Cooper & MCS
  102. Gasoline
  103. What's the most gas you've put into your mini?
  104. Rust :: door sill area of '02-'05 MINIs
  105. Xenon out - must replace both?
  106. mini cooper spontaneously goes on fire April 29, 2006
  107. Wierd Clicking Noises...
  108. Code 2096 "Post CatalystFuel Trim SystemToo Lean, Bank 1
  109. MINI Engines are budget origin?
  110. Help..please....Mini down wiring short...probably
  111. Mods and Inspection
  112. My car is wanting to die.. Please help!
  113. Small amount of oil around plugs
  114. Dipstick/checking oil
  115. I need a BIM-COM beta
  116. Help! Rain screws up remote locking?
  117. Intake Info. Needed
  118. trouble starting
  119. Uh Oh...I hope this isnt too serious!
  120. Help! Power lag on cold start
  121. Need part number..
  122. parasitic draw on battery
  123. Vibration at 3k rpm
  124. 2006 MCS Automatic Owners!!!
  125. question on narrowband oxygen sensor
  126. Need Pin-out for BMW ecu
  127. HELP!!! I have a gremlin in my mini!
  128. Variations in Serpentine belt size?
  129. Colder Plugs Part #?
  130. Service Engine Soon
  131. Toledo Mini Owners
  132. HELP NEEDED - JCW Intake Install
  133. Oil Service Reccomendations
  134. Which Coolant to refill?
  135. Bleeding Clutch Slave Cylinder
  136. Coil Wiring
  137. Battery failure so suddenly??!
  138. Confused about torque specs
  139. Driver's Side Seat Part Needed
  140. Artoo passes 50,000 miles this weekend...
  141. Squeaky Mouse in the Trunk...
  142. HELP! Car at dealer, needs flywheel, more
  143. Diagnostics Tester Fault
  144. Severe loss of power
  145. 1st gear rough and low oil level
  146. Need assistance from MCS owners
  147. Odd "Clacking" noise... any ideas?
  148. What makes a cat obd2 compliant??
  149. Shift Light Install
  150. sc / crank pulley question
  151. P0693 Fault Code - know what this is?
  152. Would adding a high flow cat trip a o2 sensor?
  153. Seat Height Adjuster problem
  154. What needs to be greased?
  155. First oil change - opinions?
  156. Installed camber plates & have change in DSC behavior???
  157. Disadvantages of 15% Pulley?
  158. Experience with TMS Pulley?
  159. Radiator coolant(Mini cooper)...
  160. CAI Intake noise question...
  161. CD Player question...pls help
  162. Overheating at idle. All fuses are OKAY. Ideas?
  163. Conversion to E85 Ethanol
  164. fresh air intake
  165. Pulley question
  166. Intermittant loss of power steering...
  167. 04 MC automatic won't start
  168. MCSa Rough Startup
  169. 99 Octane Oh Boy!
  170. whinning noise...not stopping
  171. Smoked clutch affects boost gauge?
  172. Interior door handle stopped working
  173. Chirping sound at take off
  174. Leaking Brake Master Cylinder?
  175. Clean your intake!
  176. Power Steering Issues
  177. Gurgling Sound near steering wheel?
  178. Pulley question
  179. Exhaust Burble... Goes Away w/ Upgrade?
  180. P1229 - throttle potentiometer adaption fault
  181. Anyone doing compression checks?
  182. *Air Horn installation*
  183. O2 Sensors (where to buy)
  184. Air bag light on
  185. window problems
  186. Bad sound
  187. MCS Service Engine Soon light...less than 1 day old!
  188. tire pressure sensor question...
  189. Can't open boot, Help
  190. MINI weight... GTech info
  191. Insane fast blinker...
  192. Really Loud Fan Sound!!??!!
  193. **help Needed**
  194. Auto Leveling headlight not working properly
  195. Hum from RF wheel/tire
  196. Monitoring Software ....
  197. alta panel filter - which way is up?
  198. o2 sensor circuit malfunction
  199. Question regarding "specialty" tools for clutch upgrade
  200. Red Line oil viscosity?
  201. Repair Advice for last 50K Service?
  202. Power Steering failed and came back.
  203. SES light options
  204. MAP Sensor Question
  205. 2004 Mcs On Fire!
  206. Brake sensor question
  207. Brown coolant
  208. Alignment at dealer?
  209. Input shaft seal leak
  210. How to install a tag on the front of your Mini?
  211. Car Shakes while STOPPED! need help!!
  212. Pulling during shifting
  213. 2005+ How to Reset Oil Change Counter!!?
  214. Engine break-in?
  215. How 2 clean your IC???? need help
  216. Question on replacing the Fan Assembly (radiator)
  217. Help! My MINI is Sick!
  218. Costco gas - good for my MINI?
  219. Squeaking Pulley
  220. transmission linkage?
  221. Clunky '05 Getrag trany? (5 spd)
  222. Sunroof Noise
  223. Flushing/bleeding clutch
  224. Adjusting gas/brake pedals
  225. DTC. P2097. Post Catalyst Max/Rich.
  226. P0456 - Evaporative emission control (very small leak)
  227. Craptastic heretic.....maybe
  228. Oil Pressure concern after oil change
  229. Clock stuck on time
  230. Radiator Hose Rub
  231. Mystery Diagnostic Code???
  232. Chrono Pack Oil Temp Sender
  233. Yo-Yo Explination?
  234. Jack Points
  235. Lucas Oil Stabilizer
  236. Dead thing in my air ducts
  237. Need to find a good metal toolbox
  238. Cruise control adjustment?
  239. I think I had a problem never before posted...
  240. Cooper Tranny Linkage Seems Dry...
  241. Inspection II (2) costs?
  242. clutch compression bolts for a flywheel
  243. Amsoil..
  244. crank pulley tool?
  245. tools needed
  246. Tachometer and computer dead (random)
  247. new horn installation wiring help
  248. Is my clutch about to go??????
  249. Coolant (etc.) Change Interval?
  250. Key question from a newbie...
