Uh-Oh.... What could I have done?
Today I FINALLY got my MINI running again... however, the ECU was just out loose and the bumper wasnt even on. So.... we unplugged the ECU, put the bumper back on... I plugged in my unichip... and I tried to start again.
tick...tick...tick....
I go check out everything in the engine and realize that I pulled a stupid and left one arm of the unichip plugged into itself, one arm of the ecu plugged in to the stock part, and one arm of the ecu plugged into the unichip.
I unplug the unichip and try to start again.....
Now I have noticed that when I try to turn the ignition the headlights flicker with the ticks and the windows roll down a notch at a time with the ticks.
Now I am stumped. I checked all of the fuses that are in the engine bay and they look fine. I can check the ones in the foot well tomorrow when there is more light. What the hell could I have done? I really hope I dont have to shell out the cash for a new ECU
You are supposed to disconnect the battery before disconnecting the ECU. Hopefully you didn't fry it. Try disconnecting the battery and re-installing the ECU and unichip. Say a little prayer to the MINI gods and you might be fine. . .
Originally Posted by MSFIT
even though it was plugged in funky it did try to start at first...then it started just clicking after that...
its worth a try..
my car kinda did that after they left the key in position 2 when towing it to edge onetime...got to edge and it just clicked and flashed
Originally Posted by JCampos
I doubt it... a low battery wouldnt make the lights flicker and the windows roll down
Hell yea... just some odds and ends to tie up... change rear brake rotors, flush the fluids, put air in the tires.... thats about it
Got some new plugs and a webb intake on the way also
