Part No. 61.13 6 914 209 - 01 ??
Does anyone have a parts list and can tell me what it is? After getting my MINI back from the dealer for some warranty work, I discovered a large chunk of rubber (BMW part no. above) uncerimoniously deposited on the floor. It's roughly in the shape of an equilateral triangle about 3 inches on each side, and is about an inch thick with various slots and grooves as well as one hole. It has a split to the hole with a little plastic connector about a half inch long holding the split together. I'm kind of curious to find out what they failed to put back together right. Since I had it in for a variety of items it could be from the dash panel area or a steering part.
sounds like http://www.realoem.com/bmw/showparts...67&hg=22&fg=10
number 3...do you have a pic of it?
Here is a list of the part numbers that star with 61
http://www.realoem.com/bmw/partgrp.d...id=48021&hg=61
Unfortunately, the dealer quickly recovered the piece saying that it was a part off a BMW model that somebody at another Dealer (thank you, TATE)used to geri-rig a dealer option into place. (I think the driving lamp relay). Anyway, didn't have a chance to get a pic. It is interesting that the part number stamped on the rubber triangle doesn't match anything on the BMW system. The triangle had sharp edges with a hole in the middle. I believe the piece served as a grommet originally and does fit the group 61 category.
ryGuyMCS
Oct 20, 2015 02:24 PM
nomar116
Aug 21, 2015 04:36 PM
