Have you had this problem? Limp Mode / Bypass Valve
Old Jul 14, 2006 | 07:28 PM
sumfabgear's Avatar
sumfabgear
I was driving on the freeway (75-85 mph) when all of a sudden, the transmission shut down. Luckily, I was able to get over to the shoulder. I put it in neutral and coasted to a call box. Tried turning it off/on. It started and drove rough (later found out that's "limp mode.") Turns out it was a faulty bypass valve, and not uncommon.
Old Jul 14, 2006 | 07:40 PM
dave's Avatar
dave
pug poo picker-upper
Thread moved and title changed to make it more descriptive
Old Jul 14, 2006 | 07:50 PM
qweewq12's Avatar
qweewq12
yep... I did.. had to change bypass, new software and some other darn thing...
Old Jul 14, 2006 | 08:31 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Yes. It has happened to lots of us. My personal opinion is that there are a LOT more CooperSs that have bad bypass valves and the drivers don't drive them hard enough to notice. It's not like the car will idle or run bad so if someone doesn't accelerate to the redline they will never know. I asked my service advisor if they routinely check the valves and he said not unless there is a complaint. I suggested lots of people will notice this after their warranty runs out even though the valve went bad within the 50,000 mile warranty. He just smiled. I did not.
Rich Wolfson
Old Jul 15, 2006 | 12:21 AM
sumfabgear's Avatar
sumfabgear
Thanks Dave. Still learning...
Old Jul 15, 2006 | 05:28 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Had a bypass valve go bad on mine, car wasnt making any power and wouldnt get out of its own way .
It all happened under warranty so dealer fixed it.
Old Jul 15, 2006 | 05:52 PM
MCLeonard's Avatar
MCLeonard
This happened to my Mini as well. The bypass valve stays open so the boost pressure is released. It drives like a standard Cooper but with a dragging supercharger taking 30 more hp away. My car would shut down over 4k rpm with more than 1/2 throttle. The power loss is noticable right from the start. My gas milage improved though. The dealer replaced the bypass valve under warranty. The valve isn't so expensive, but the labor to get to it is. From what I read this is a common problem.
Old Jul 17, 2006 | 07:17 PM
apexer's Avatar
apexer
I got a new BP Valve from Detroit Tuned. $125.00 and made all the difference in the world
Old Jul 17, 2006 | 07:32 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
I'm interested, how difficult was it to change out your bypass valve? I'm just guessing that you did it yourself.
Old Jul 18, 2006 | 02:18 AM
Bster's Avatar
Bster
It's not difficult to DIY. No special tools needed as well. Just a couple of spanners and follow instructions given by Detroit tuned and you'd be a happy camper!
Old Jul 18, 2006 | 11:10 AM
apexer's Avatar
apexer
It wasn't too bad. A friend & I did it in about 1hr. Don't even try to re-use the oem hose clamps. I even have the same small channel locks Randy uses and still a bi-ch.
Old Jul 18, 2006 | 01:58 PM
pberry51mini
No Fear Gear
Cool, ordered one from Detroit today! Thanks!
Old Jul 25, 2006 | 08:53 AM
topgearnut's Avatar
topgearnut
Hi,
I've got a car that has a really rough idle and only seems to start now in limp mode - could the bypass value on my mcs gone bad - how can i check if this happened?
Thank you
TopgearNut
Old Jul 25, 2006 | 09:18 AM
Dr Obnxs's Avatar
Dr Obnxs
Think about what the bybass valve does. It opens at HIGH vacuum....
so for Idle, it would be open anyway, so a bad BPV shouldn't affect idle. It will affect operation when it's supposed to close. When you put your foot down.
If you have a rought idle, it's probably somethings else....
Matt
wkp1219
Nov 13, 2015 07:52 AM
PEterChoqu
Aug 26, 2015 08:33 AM
Dsinkster
Aug 17, 2015 03:24 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
quickquest88
Aug 8, 2015 08:45 PM
