Low tire light came on an on an on
Old Apr 8, 2008 | 04:53 PM
bodman's Avatar
bodman
Added air to all 4 tires and light will not go out . Is there a procedure to make it happen.
Old Apr 8, 2008 | 05:17 PM
volki
Yes there is....
You have to reset the system. Unfortunately, it does not measure the air in each tire, it just detects rotational differences between wheels.
Turn the ignition until all the lights turn on in the odometer. Hold down the button under the emergency brake (yes, there is a button there) for about 5 seconds. If the low tire pressure light was blinking, it should become solid at this point. Start the engine and drive away. It should go off in 10 seconds or so....
Old Apr 8, 2008 | 05:41 PM
bodman's Avatar
bodman
Thanks that did it
The only thing is the light did not go out until I turned off the car and back on . AND YES THERE IS A BUTTON UNDER THE BREAK
Alkaidovich
Jan 30, 2021 01:35 AM
JamJam43087
Aug 16, 2015 02:02 PM
Emnotek
Aug 13, 2015 05:47 PM
