how bad the power steering has to be to get an warranty
Old Sep 17, 2008 | 12:31 AM
rustspot's Avatar
rustspot
my warranty ends at October, and the PS is making some noise, not too loud but noticeably louder than normal i think. you think mini would replace it if it's only little louder than normal?
Old Sep 17, 2008 | 04:44 AM
roaduscarnivorous's Avatar
roaduscarnivorous
what kind of noise? the usual whine and wheeze or something selse?
Old Sep 17, 2008 | 07:43 AM
JeffM's Avatar
JeffM
bad, but can still be working
I had my pump replaced under warranty last year due to a loud grumbling noise (which could also be felt as a vibration in the floor). The steering never stopped providing assist, but the pump was clearly not healthy. MINI didn't argue a bit. I had previously disconnected the pump fan for a few minutes to rule that out as the noise, and I let them perform that check too, so they knew for sure where the issue was.
So if your noise is bad enough, take it in for a check. I just complained about excessive pump noise when I made the service appointment, and when I dropped it off I sat in the car with the technician and showed him exactly how to make the noise appear and what I thought it was. End result: new pump, no charge, happy MINI owner!
Old Sep 17, 2008 | 02:11 PM
darksun's Avatar
darksun
How does a used pump sounds like ? My pump looks ok but i hope it does not die... :(
Old Sep 18, 2008 | 12:45 AM
rustspot's Avatar
rustspot
noticeably louder than another mini with 20000 km and my car's at 60000. not sure if that's enough for a new pump under warranty.
Old Sep 20, 2008 | 12:54 PM
1FSTMINI's Avatar
1FSTMINI
what type of noise are you hearing though?
it will make a whining noise at a stop if you turn the wheel...thats the electric servo in the pump.
Etrain
16
Aug 5, 2024 04:37 AM
JPMontes3
Aug 23, 2015 01:26 AM
azntaiji
Aug 13, 2015 03:24 PM
minipopkart
Aug 13, 2015 05:22 AM
