Two things???
Old Oct 2, 2006 | 08:13 PM
Mini 10S's Avatar
Mini 10S
Two things???
The driver side window does not always drop down and go back up when you open and close the door like its supposed to. Anyone have that problem? Also, how do u remove the plastic cover of the white reverse light on the back of the car? Thanks!
Old Oct 3, 2006 | 03:50 AM
ProfessorDave's Avatar
ProfessorDave
Re: your first question, the motor for the power windows can develop a flat spot on them apparently from moving the window that half and inch over and over. It probably means that the motor is failing, but you can try the quick fix of pounding on the door liner near the door handle and speaker (do a search here on NAM for more specific instructions). Many have found this to work.
Does the window operate normally otherwise?
Good luck!
Old Oct 3, 2006 | 06:38 PM
Rawhyde's Avatar
Rawhyde
If the window works ok, but doesn't drop when opening the door, try recalibrating the window. Just raise the window and hold the "up" toggle for about 6 seconds. Then try it.
Rawhyde
Old Oct 3, 2006 | 09:47 PM
Fatherdeth's Avatar
Fatherdeth
The second question:
You can't pull off the cover to the reverse light without cutting the seal around it. If you are reffering to taking the housing out to change the bulb, just take a small flat head screwdriver and pry one side out a little, then pry out the other side. Or you can do it the hard way and reach under the bumper and squeeze the tabs. Very hard if you have an "S" model.
patsum
26
May 29, 2021 06:29 PM
riff42
Sep 22, 2015 03:07 PM
cdemarco4
Sep 10, 2015 10:14 AM
Panik
Sep 9, 2015 08:36 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
