Messed up shifting
Old Aug 22, 2006 | 01:21 PM
Adnuo's Avatar
Adnuo
Messed up shifting
My 2005 MCS is nearing it's 50k warranty endcheck, and recently the shifting has been weird. It will randomly miss 2nd gear, engaging halfway and then it feels like it "kicks" the gear back into neutral. It also becomes hard to find certain gears, especially reverse, but it will happen to any gear. I pulled the shift boot off and the white plastic ring around the shift bearing is cracked in a few places, so I don't know if I have a broken shift bushing or if it could be something else. I've also heard of the battery cable on some of the S's getting in the way of the shift lines and causing gears to get lost in the shifttrack.
Anyone else experienced this, or have any input? Also, would something like this be covered under warranty?
Old Aug 22, 2006 | 01:39 PM
thulchatt's Avatar
thulchatt
I would be concerned
I have had this happen with a honda and it was the syncro. It went from popping out of gear to not staying at all.
You should get it checked ASAP before it gets worse.
Old Aug 22, 2006 | 01:55 PM
joey1320's Avatar
joey1320
the white plastic around the shifter should not be broken. take it in for repairs.
USNAE2
16
Jun 17, 2022 07:17 AM
OutMotoring
Mar 3, 2017 06:29 AM
Mazarin
Electrical
Dec 7, 2015 08:23 AM
02miniSguy
Nov 17, 2015 10:29 PM
bahman
Sep 30, 2015 01:59 PM
