Front upper strut bolt sheared off....crap!!
Old Aug 18, 2006 | 01:32 PM
TiMINITim's Avatar
TiMINITim
First, before anyone can ding me on it, I was using a torque wrench !!!!!
I was in the process of removing the front strut brace. I had put on 5 of the 6 bolts when, on the sixth bolt, it sheared off at about 25 to 27 Nm . According to my Bentley manual, they should all be torqued to 34 Nm.
So, is there any way to replace that one stinking, miserable, no-good excuse for a piece of metal, bolt?? Please don't tell me I need to replace the whole strut assembly:impatient !!!!!
Thanks!!
Old Aug 18, 2006 | 04:39 PM
JustGo4It_'s Avatar
JustGo4It_
You need to replace item #5 the "strut top mount" on page 310-12. I don't believe the studs are service item parts.
Old Aug 18, 2006 | 04:47 PM
DragonSlayer's Avatar
DragonSlayer
Sounds like a good excuse to get some Adj Camber plates
Old Aug 18, 2006 | 06:11 PM
rkw's Avatar
rkw
JustGo4It is right. It is #1 (Guide Support) in this diagram.
I've sheared off a bolt too, and on the other side the threads were stretched so the plates had to be replaced on both sides. I had stupidly tried to use the same torque wrench I use for my wheel lugs. 34 Nm (25 ft-lbs) was at the very bottom of its scale, and the reading was way off. My mechanic said that at such low values, I should be using a torque wrench capable of foot-ounce accuracy.
Old Aug 18, 2006 | 06:31 PM
TiMINITim's Avatar
TiMINITim
Well, I guess that's not too bad, but it looks like I'll still need to take the whole assembly apart, get a spring compressor, blah, blah, blah. So it goes!
As for the adj camber plates, I like the idea but I was taking the strut brace off as I get ready to sell the MINI. Not to fret though....the GP will be in soon!!!
Thanks for the help!
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Toolman
Jan 20, 2016 06:50 AM
FLYM1N1
Aug 15, 2015 11:20 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
