Air conditioner/overheating Help!
Old May 9, 2007 | 04:42 AM
kevin barrett's Avatar
kevin barrett
It seems that my AC button starts to flash when I'm in traffic, then cuts out completely. Is this due to overheating , any suggestions would be appreciated, [I'm a newbie].
Old May 9, 2007 | 06:21 AM
daflake's Avatar
daflake
Sounds like it needs to be charged.
Old May 9, 2007 | 01:10 PM
techtipz's Avatar
techtipz
Is the car overheating??
Old May 13, 2007 | 05:25 AM
kevin barrett
It overheated once, I filled the reseuvour to the correct level and I haven't had a problem since.
Old May 13, 2007 | 10:26 AM
daflake's Avatar
daflake
When the car overheated, it may have caused the AC to also overheat. Typically the until will vent the freon to keep the compressor from being destroyed. This happened in another one my older cars. I would have the AC serviced to see if the problem goes away.
Old May 13, 2007 | 04:02 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Most likely your radiator fan is not working. Check fuse F05 in the underhood fuse box. If it is blown, chances are you have a siezed power steering fan. There are a number of threads addressing this issue. Problems like this begin to show up as summer approaches and people begin using their a/c more.
Old May 13, 2007 | 07:35 PM
Foxtrot_Xray's Avatar
Foxtrot_Xray
Greatbear hit it on the head - had the same problem myself. When moving, there's anought airflow to keep the radiator cool. In stop and go, it can't keep the engine cool 'nuff. You will probably see your temp gauge top out, and the engine run rough..
Replace the fuse and get the fan fixed ASAP...
Old May 14, 2007 | 06:03 PM
kevin barrett
Thanks for the advice, I will attend to this ASAP.
Old May 14, 2007 | 06:27 PM
kevin barrett
You guys were right by the way, just checked it, the fuse was blown. I guess I will make that trip to the dealer.
sleek55044
Oct 14, 2016 01:52 PM
Mini Hooper
Sep 17, 2015 01:58 PM
Sep 10, 2015 11:55 AM
M7Speed
Sep 3, 2015 07:48 AM
