AC is busted Need help Locating Sensors...
Old May 30, 2008 | 08:08 AM
bda1855's Avatar
bda1855
My wife's MC has the auto climate system, the AC worked just fine up until memorial day when it stopped blowing cold. I searched around on this site and found some threads saying it may have low R134 so i bought a can hooked it up and nothing.
It appears that the compressor is not turning on at all so the system wont pull the R134 into the system....
Question is does anyone know where the Condensor and the Low Pressure switch are located? I need to test the Switch and jump the sensor so i can pull the R134 into the system and see if its just low or if the switch is actually bad.
Sucks... but at least its not 110 outside yet...
Old May 30, 2008 | 09:30 AM
03BRG's Avatar
03BRG
Be carefull of how you shot gun a problem like this. Get a service manual and good luck
Old May 30, 2008 | 09:44 AM
bda1855's Avatar
bda1855
Yeah thats why i asked if anyone knew where the canister with the switch was located. I already ordered the service manual CD-ROM...
Old May 30, 2008 | 11:14 AM
OctaneGuy's Avatar
OctaneGuy
Obvious question but did you check the fuse/relay for the AC? They are both under the dash where the fuse panel is as well as inside the engine bay next to the ECU.
Old May 30, 2008 | 12:17 PM
bda1855's Avatar
bda1855
Yeah checked the Relay under the hood, the 30A fuse under the hood and the 5A fuse under the dash...
am i missing something?
Old May 31, 2008 | 09:49 AM
chadtoolio's Avatar
chadtoolio
I understand what you are saying...it would be that, "hooking up a can", and properly diagnosing a problem are 2 very different things. I think it is noble when someone does research and tries to fix something thereselves, but AC systems can be very dangerous, especially when charging with a can(which can explode) if pressure is introduced to it.
Check fuses and then...
First thing I would do is to get a set of gauges hooked up and actually look at the pressures....Are they low?
Second, if the pressures were ok, is to check for 12v at the compressor.
Then start looking at relays, etc...
richardsperry
Jul 30, 2018 04:48 PM
vbmike
Oct 15, 2015 04:32 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
ir0nhid3
Sep 18, 2015 07:52 AM
old81
MINI5280
Sep 3, 2015 09:03 AM
