Rounded off brake bleeder screw
Old Apr 26, 2008 | 02:54 PM
Slant's Avatar
Slant
Old Apr 26, 2008 | 04:20 PM
ga1051's Avatar
ga1051
Spray away. Let it soak and hope that it doesn't break.
Good Luck.
Old Apr 26, 2008 | 05:44 PM
Yo'sDad's Avatar
Yo'sDad
Spray it with P-Blaster and let it soak for a day. Spray the other three also. Buy a replacement or four. Apply a vise-grip plier and unscrew it...install a new one with a tiny amt of antisieze on the threads only.
YD
Old Apr 26, 2008 | 06:02 PM
gnatster's Avatar
gnatster
Bleeder Valves are available from the dealer.
34-11-1-160-190 is the part #
You may be able to pick one up at an auto parts store too. Size is M10x1.
Old Apr 26, 2008 | 07:09 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by Slant
I just rounded off one of my brake bleeder screw on my 03 MCS. Does anyone know if it unscrews completely from the caliper so I can get a replacement?...
It unscrews but be careful you don't break it. Let it soak a bit with Blaster and use a vice grip to gently unscrew it. If you break it is a much bigger job.
Get 4 stainless Speed Bleeders and they will not only be strong but it makes bleeding or changing fluid a snap even with no help.
Also while you're at it get the right wrench for the job and next time they won't round off. A 6 point bleeder wrench is the way to go. What were you using when it rounded off?
Rich
Old Apr 26, 2008 | 07:28 PM
Slant's Avatar
Slant
Old Apr 27, 2008 | 09:58 AM
thulchatt's Avatar
thulchatt
Rich
What size Speed Bleeders? I have not seen them list an application for the MINI.
I really like to use Speed Bleeders as it make changing the fluid a one person job.
Old Apr 28, 2008 | 06:00 PM
Tom D's Avatar
Tom D
I don't know the size but if you E-mail Speedbleeder they do have them for the MINI.
Old Jul 1, 2008 | 01:31 PM
Calaway16's Avatar
Calaway16
Where can I get a bleeder screw for the clutch? I just went to the dealer and the dude at the counter said that I had to buy a whole new clutch slave cylinder for 75 dollars . I have a hard time believing that I can't just get a bleeder screw from them but whatever.
Old Jul 1, 2008 | 03:48 PM
Calaway16's Avatar
Calaway16
If none is available and if someone knows the specs, I can machine my own.
Old Jul 6, 2008 | 12:18 PM
apexer's Avatar
apexer
Not sure but I believe the bleeder screw for the clutch is plastic.
Old Jul 6, 2008 | 05:24 PM
Calaway16's Avatar
Calaway16
It is most definitely plastic. I've taken it off completely. Just curious but what made you think I thought the screw was plastic?
Old Jul 6, 2008 | 06:15 PM
apexer's Avatar
apexer
You said you could machine your own. Don't know of many that can do a good job machining plastic. Aren't both the clutch slave and the bleeder screw plastic?
Old Jul 6, 2008 | 07:52 PM
Calaway16's Avatar
Calaway16
Machining plastic is pretty straightforward. Yes, both are plastic.
Old Jul 7, 2008 | 06:03 AM
apexer's Avatar
apexer
Sure, pretty straightforward for you...
Old Jul 7, 2008 | 06:09 PM
Calaway16's Avatar
Calaway16
baaah you could do it. I'm self taught I mean sheesh
rtk90
Aug 29, 2019 09:08 AM
techgearpro
Jul 23, 2019 07:09 PM
Gremothra
Sep 9, 2015 08:42 PM
PelicanParts.com
Tires, Wheels & Brakes
Sep 9, 2015 01:37 PM
wildwestrider
Sep 4, 2015 06:25 AM
