How difficult is it to change the valve cover gasket?
Old Apr 18, 2008 | 12:46 PM
discodan's Avatar
discodan
would i be able to do this myself with basic tools? or should i have it done professionally? thanks in advance.
Old Apr 18, 2008 | 12:57 PM
Guest's Avatar
Guest
I'm not sure of any technical requirements other than a wrench capable of removing the bolts. I forget what size it requires, and I'm not sure if the bolts need to be replaced afterwards (Don't think so).
Why do you want to change it, leaking?
Old Apr 18, 2008 | 01:00 PM
naffets's Avatar
naffets
+1 assuming you have a cooper.
A little more involved with the S model.
Old Apr 18, 2008 | 07:59 PM
discodan's Avatar
discodan
it seems to be leaking and i was a little low on oil, so just for peace of mind. i do have a Cooper S btw. would Loctite or something like that be needed?
Old Apr 19, 2008 | 12:50 PM
discodan's Avatar
discodan
anyone else have some advice i'd really appreciate it.
Old Apr 19, 2008 | 03:34 PM
Funk_Flex's Avatar
Funk_Flex
You'll probably need the specific sequence in which to tighten down the valve cover bolts and a torque wrench.
Old Apr 19, 2008 | 04:04 PM
chadtoolio's Avatar
chadtoolio
Tightent the bolts from the center and work your way outwards, like this
7 5 1 3 9
10 4 2 6 8
I don't use any specific torque, just the German torque measurement called "Goodentite"
You have to remove your intercooler though on an "S". Not difficult, just take your time...and replace the spark plug tube seals also(probably the most difficult part). Grab hold of part of the spk. plug tube seal with a pair of large channel locks and lever them out. Use a seal driver or something similar to get them in the valve cover all the way.
Old Apr 19, 2008 | 08:06 PM
teknotexan's Avatar
teknotexan
Tube seals!! How could I have forgotten this!! Back to the dealership.
I recently purchased a 2002 MCS, which is showing a bit of a leak from the valve cvr as well. Some FIPG and a new gasket will fix that!!
Old Apr 22, 2008 | 09:20 AM
detroitchilimcs's Avatar
detroitchilimcs
you need to buy new tube seals when doing this job on the S? I am in the same situation almost.... just bought an 02 mcs with a leaky valve cover gasket...
i take it this is a common problem with this car?
Old Apr 22, 2008 | 11:09 AM
Ancient Mariner's Avatar
Ancient Mariner
Not a common problem, but new tube seals with any OH cam engine of this type are a must.
Old Apr 22, 2008 | 01:16 PM
AliceCooperWA's Avatar
AliceCooperWA
I don't think it is a common problem. But if the cover is removed a couple of times by a previous owner and the gasket is not replaced, it could cause leaks.
09R56
Nov 16, 2022 10:49 AM
Lex2008
Aug 16, 2015 08:33 PM
azntaiji
Aug 13, 2015 03:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
