noise when starting /smell while running. Help Please!!
Old Jul 7, 2008 | 08:55 AM
Seancusmc's Avatar
Seancusmc
I think I amy have damaged my clutch. I'm no mechanic and I wanted to know what you guys thought before I take it to a mechanic or a dealership.
This is a 2005 MCS with a few mods I am told - 15% reduction pulley, exhaust, and chip. It has been running fine for 40,000 miles with those mods.
I can't verify those parts are in, I am a new owner just taking previous owners word for it.
Here is the Video
The sound that is concerning me is when the car is started as the engine turns over. It's the squeeling sound 11 seconds into the video.
After some driving, when sitting at a light or pulling into a parking spot, the drivers side smells like burning plastic. The passenger doesnt smell this even with the window open. It does not matter whether or not the Air conditioner is on.
Old Jul 14, 2008 | 11:27 PM
Seancusmc's Avatar
Seancusmc
Well that was the noise of a shattered pressure plate in the clutch if anyone is interested.
(cricket cricket)
Or if anyone is here?
Old Jul 15, 2008 | 06:09 AM
Xymox's Avatar
Xymox
That sucks. How much will that set you back to replace?
Old Jul 18, 2008 | 11:54 AM
k_h_d's Avatar
k_h_d
So what was the outcome? Did you take it to the dealer? Did it have other symptoms or leave you stranded?
Old Jul 18, 2008 | 11:37 PM
Seancusmc's Avatar
Seancusmc
The stealership wanted $1,800 to replace the entire clutch and an additional $900 to replace the flywheel.
I called a transmission shop, they towed it for free and with all the labor and parts it came to $1,600.
Old Jul 19, 2008 | 05:56 AM
k_h_d's Avatar
k_h_d
Did they replace with a OEM clutch?
Old Jul 19, 2008 | 09:30 AM
Seancusmc's Avatar
Seancusmc
To be honest I'm not sure, he said something about higher PSI.
I inquired about a lightweight flywheel as well, but his opinion was to use an OEM. The OEM flywheels are much more expensive, but he said it was best to use it and performance gains from a lightweight flywheel would be immeasurable once the car is in gear.
To save money, I got one resurfaced from a wrecked mini.
Old Jul 23, 2008 | 08:24 AM
Seancusmc's Avatar
Seancusmc
Just got the car back. The noise is still there, The mech says its probably from fragments of the clutch sticking in the starter, they should work themselves out in time.
The clutch isnn't higher PSI, but it's Kevlar, which is a better material than the asbestos or whatever is used in the OEM clutch
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
maestro39
Oct 27, 2015 02:38 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
patrioticmini
Aug 20, 2015 10:54 AM
