CV Joint Question
Old Nov 10, 2006 | 06:08 PM
ronstoys1's Avatar
ronstoys1
CV Joint Question
I think I have a CV Joint problem. I have a 2003 Mini - manual 5 speed. Can anyone tell me how to check for worn cv joints. Thanks, ronstoys1
Old Nov 10, 2006 | 08:19 PM
herbie hind's Avatar
herbie hind
i don't know a specific check. they're usually very noisy (noticably so ) . sometimes turning the wheel will increase the clicking kinda crunching noise. best done at slow (5 mph) speeds. the noise is in direct proportion to speed. like if you slow way down to a walk you'll get a crunch ....crunch...crunch . and itll speed up with you as you do .
Old Nov 11, 2006 | 10:10 PM
Fatherdeth's Avatar
Fatherdeth
Also, sometimes if you put the car in reverse and back up while turning, you'll get a harsh grinding sound. Basically imitate backing out of a parking space.
Check your boots also. You have to really check as sometimes the boots will have a tear that is not quite so noticeable. A torn boot can indicate that you have a bad CV joint.
Old Nov 11, 2006 | 11:47 PM
Gromit801's Avatar
Gromit801
Inspect the boots for any tears or holes, if there is, the boots must be replaced immediately. Clean off as much of the old grease as you can before packing in the new grease. Give the axles a really good shake and feel if there's any play (there shouldn't be).
Old Nov 12, 2006 | 06:18 AM
ronstoys1's Avatar
ronstoys1
Thanks everyone for your help. Ron
Supertractor3
Apr 7, 2017 11:16 AM
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
rob&JCW
Sep 10, 2015 12:06 PM
Robree
Sep 9, 2015 08:43 AM
