Has this happened? gas gauge stuck on empty
Old Nov 25, 2006 | 12:19 AM
retroom's Avatar
retroom
I've had this happend three times in 4 years. I start the car, the gas gauge stays on empty. The car runs fine, when I restart, the gauge is back to normal. No problems, just a little disconcerting. I have a 2003 Cooper.
retroom
Old Nov 25, 2006 | 04:21 AM
TampaMCS's Avatar
TampaMCS
Mine, an 06 has done it twice, both times it was after filling it way up.
Old Nov 25, 2006 | 09:51 AM
RonP's Avatar
RonP
Mine did this so I took it in, they had to replace "Replaced Fuel Tank Sensor 2 (fuel level sensor)". At least that's what it says on my service ticket. It's worked perfectly since.
Old Nov 25, 2006 | 11:23 AM
Gromit801's Avatar
Gromit801
Never happened to me. Once the gas pump clicks off, I don't give it that extra squeeze on the trigger. Maybe that's the secret, don't know.
Old Nov 25, 2006 | 11:26 AM
RonP's Avatar
RonP
It has nothing to do with how you fill the tank.
Old Nov 25, 2006 | 12:36 PM
Dr Obnxs's Avatar
Dr Obnxs
Fuel sender is going...
My car came that way (non-documented design feature) and it's reccured. Fuel sender.
Matt
Old Nov 25, 2006 | 09:45 PM
retroom's Avatar
retroom
Fuel sender
Thanks for the inputs. My warranty is almost up, is there an error code generated for this event? Otherwise, how does the dealer justify replacing the sensor under warranty or will the dealer just replace it?
retroom
Old Nov 25, 2006 | 10:14 PM
valcom111t's Avatar
valcom111t
It's an evil plot by the oil companies and George W. to get you to buy more gas.
Old Nov 25, 2006 | 10:52 PM
Dr Obnxs's Avatar
Dr Obnxs
One of the modules...
stores an error code. The factory scan tool can read it.
Matt
rob&JCW
Feb 13, 2023 07:03 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
Herleman
Aug 16, 2015 06:41 PM
dchang0
Aug 10, 2015 03:37 PM
