traction, ABS, and tire lights on at the same time
Old May 3, 2010 | 05:57 AM
ryan319's Avatar
ryan319
hi, i have a 05 MCS, 6-speed with 50K on it. this problem started a few months back and has become more regular lately. when i hit a big bump in the road, or sometimes just when reversing from my driveway, the yellow warning lights for traction, ABS, and tire pressure all come on at the same time. if i restart the car, they all go off. it seems to occur more frequently when it rains. any idea how to troubleshoot this? i'm guessing a bad wire on a wheel sensor but i haven't checked them out yet.
the car is lowered with bigger sway bars and adjustable end links. could this have any impact?
thanks, ryan
Old May 3, 2010 | 06:12 AM
NightFlyR's Avatar
NightFlyR
sounds like the wheel sensor / wire try cleaning them all as that is normally the problem. I had 1 also last year and it also acted up more when it rained
Old May 3, 2010 | 09:31 AM
PerkMini's Avatar
PerkMini
I had this problem. It's the sensor and I don't recall it being too expensive to replace, maybe $150 at my Mini shop here in Tulsa.
Old May 3, 2010 | 10:07 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I had a front ABS Pulse Generator go, and when wet triggered the "trifecta" of lights on my dash....
FYI: When the lights are on, those MINI components are also deactivated.....
part no. 34526756384 - $130.00.
Item 2 below.
About an hr labor by some mechanic shops, more probably at dealer.
System would reset after shut down and restart, then lights would come back about 100' down the road.
If you have an Auto Zone or Advanced Auto nearby, you may be able to pull the code if they can loan you the reader...
Old May 3, 2010 | 06:30 PM
Mister-Aandrew's Avatar
Mister-Aandrew
i had this, and it ended up just being the car off of alignment kind of. took it to a mini shop here and he plugged it into the comp, adjusted the alignment of the steering wheel, and it was good to go. i though it was a speed sensor, but to my luck it wasnt.
Old May 4, 2010 | 02:13 PM
ryan319's Avatar
ryan319
i pulled the sensors on the drivers side today as i suspected it would be a sensor on that side based on the bumps that trigger the lights to come on. the rear sensor looked relatively new. the front one was all crusty. i cleaned them both and now all three yellow lights are on all the time. i think the right front sensor is bad. is it the same part# for all 4 wheels?
Old May 4, 2010 | 02:21 PM
ryan319's Avatar
ryan319
nevermind i found it. gray raven, thanks for the advice. better check your price though, i found an oem sensor for $65 and an aftermarket one for $32.
Old Jun 11, 2010 | 12:15 PM
LenQ's Avatar
LenQ
@ryan319 - where did you find it for that price? not doubting you, but are you sure it is the correct item? usually they run about $100. (but i am always interested in a cheaper version if available )
Old Jun 11, 2010 | 12:36 PM
ryan319's Avatar
ryan319
i found the aftermarket one on ebay but it was referenced to the OEM part number so i figured that it was the correct one. i found the OEM one another site, can't remember the name but it was easy to find by putting the part number in a google search.
i went with the aftermarket one from ebay as it was only $32. it arrived 2 days after i bought it fixed the warning light problem. no complaints with it at all.
Old Jun 13, 2010 | 04:49 PM
minitech829's Avatar
minitech829
most likely the left front abs wheel speed sensor
Toolman
Jan 20, 2016 06:50 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
1964geo
Aug 10, 2015 06:22 AM
Dashdog
Aug 10, 2015 06:17 AM
