Plastic Hood Scoop Shroud
Old May 21, 2010 | 05:34 PM
rtsip's Avatar
rtsip
Hey Guys,
I was wondering if that plastic piece attached to the hood scoop under the bonnet is actually functional. I removed the hood scoop to paint it and reattached it without the plastic shroud. Is it worth the effort to put the thing back on?
Old May 21, 2010 | 06:16 PM
gear-head's Avatar
gear-head
yes it's functional, in that it provides a seal between the air coming in from the scoop that then flows down over the inter-cooler.
Put it back.
Old May 21, 2010 | 06:27 PM
ranczar's Avatar
ranczar
If you're running a stock scoop and intercooler/cover, then yes, it may make a difference to you. The piece attached to the inside of the bonnet helps create a direct path for air to flow directly to the IC. That piece has (or should have) foam strips that make a seal against the cover of the IC, thereby funneling the air directly to the IC.
It's an air flow efficiency thing that helps cool the air going into the cylinders. (cooler air is air that's more dense, and contains more oxygen, which creates more power than air with less oxygen.). If more power matters to you, then put it back in.
Old May 21, 2010 | 06:34 PM
rtsip's Avatar
rtsip
While it is the stock hood scoop, I have an Alta air diverter on the intercooler so that provides a pretty similar function. I'll check to see how much of a seal it makes, but if it looks like its touching the hood, I'll probably leave the piece off
Old May 21, 2010 | 07:55 PM
GumbyLara's Avatar
GumbyLara
You are supposed to leave it off the with Alta Air Diverter
Old May 21, 2010 | 08:09 PM
gear-head's Avatar
gear-head
The Alta is/was designed so that you had to remove the stock Plastic parts.
Old May 22, 2010 | 10:25 AM
rtsip's Avatar
rtsip
Got it. Thanks guys
Old Sep 14, 2010 | 11:53 PM
chykneestweakr's Avatar
chykneestweakr
can anyone tell me if the plastic shroud is held in place by anything? i noticed my shroud is loose and was wondering if there were supposed to be screws holding it in place.
Old Sep 15, 2010 | 06:29 AM
JPMM's Avatar
JPMM
little nuts that fall off
Check the seal on that Alta diverter with paper strips through the scoop , removable putty or baby powder , you will probably have to shim it up to have the foam seals do their job.
Boverphoto
Jul 3, 2017 10:56 AM
boholio
Nov 9, 2015 03:50 PM
YO MUDA
Oct 5, 2015 04:14 PM
Sep 3, 2015 01:45 PM
MiniSMan
Sep 1, 2015 06:49 PM
