Noise when accelerating and decelerating
Old Apr 21, 2010 | 09:44 AM
thoward's Avatar
thoward
I have a noise coming from what seems under the drivers side foot area. My husband claims it is a growling noise. It only happens when I accelerate and decelerate in the higher gears. It started a couple of months ago very slight on off and on. I drive it the most and could hear it although no one else could until now it happens all the time. Any suggestions as to what it may be? I think it started after i pulled into a driveway that had a slight drop off and i bottomed out?
Old Apr 21, 2010 | 11:28 AM
cmt52663's Avatar
cmt52663
probably wide of the mark, but the first think that occurs to me...
"growling"... interesting - that suggests drive train to me, as does the on/off throttle provoking it, as does the "top two gears"
"growling" leads me to a rotating part that's moving fairly fast -- e.g. the rollers in the bearings, the gears in the box, but probably not the CV joints (but not sure on that one)
that leads me to the following two bits:
1. i would go try and diagnose it, as it's getting worse and worst case could it be expensive over time
2. i'd start with front wheel bearing and CV joint inspection, and a check of the transmission oil level as well
3. with the car on the lift I'd search for any evidence of "bottoming out" contact where it might matter
others might have better ideas though.
cheers,
charlie
Old Apr 21, 2010 | 12:29 PM
scottie10014's Avatar
scottie10014
I had something similar, but it was more of a knocking noise and generally under lower speeds of acceleration and deceleration. Ended up being a busted engine mount.
Old Apr 21, 2010 | 02:01 PM
LiquidKarma's Avatar
LiquidKarma
I have the same problem with mine
02 mc
I would like to know what you find out
Jay
Old Apr 21, 2010 | 06:56 PM
Bimjo's Avatar
Bimjo
CV joints usually click on tight turns & slow speed when they go bad. Engine/transmission mounts is a good place to start the search for your noise.
Good luck in the quest, noises can be very frustrating to find.
Old Apr 22, 2010 | 12:50 PM
LiquidKarma
So as far as I can tell it was bad baring in the transmission.
I know this now cause my trany just blew apart this morning .
(driving to the shop to get looked at)
So now i'm in need of a trany.
plaese help
Jay
Doc Pain
Mar 10, 2021 04:50 AM
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Miniwaukee
Sep 29, 2015 09:22 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
