Clicking noise on takeoff/brake
My 05 MCS has developed a "clicking" when I start to take off or begin braking (this happens both in a straight line and when turning. I jacked up the front left of the car and can reproduce the sound by trying to turn the tire/wheel by hand with most of my weight. It sounds like it is in the CV Joint, but unlike a classic CV joint going bad, I don't get the usual frequent clicking when turning. Anyone else have this problem?
eVal - I have removed the wheel and screwed the bolts in and using a bar to put rotational force on the axle, I can still reproduce the sound, so it isn't the wheels, unfortunately.
ministrone - did the axle replacement fix the problems? That is what I am leaning towards for diagnosis.
BTW - no relation to Peter
Yes changing the axle fixed the problem. The bearing change didn't fix it.
I knew it wasn't the tires as I had changed them to non-runflats with different rims.
I recently had the right axle done, as it made a more subtle clicking upon acceleration.
The loud metallic click was really prominent on the left side. Occasionally it still does, but only when I reverse, and not enough to warrant concern. Although my lease/warranty will be up in June so if I want to buy it out I'll be getting them to go over everything again.
Definitely a warranty issue. I've got a good relationship with my technician and I never get any runaround.
Hope that helps.
Hope that helps.
I thought this might help - found this Service notice on AllData:
M310105 JUN 05 Suspension - Front End Clicking/Creaking on Bumps/Turns
I do not have an account and access to the details, but it sounds promising, hope it helps - the "M310105" is the bulletin number that the tech can look up.
Does it sound like two pool ***** hitting together?
This might help you: https://www.northamericanmotoring.co...ad.php?t=44291
It happend to me a in early September. You're welcome to read the entire thread, but the first post will give you the fix. I took my MINI to the dealer; the service guy just did steps 8 and 9:
8) Re-torque nut to 134 ft-lbs.
9) Tap lip of the axle-nut back into the indentation to lock it in place. Again...use a brass drift punch to make sure you don't damage
08-19-2015 12:51 PM
Colt45Magnus
08-12-2015 06:43 AM
nismo4life
08-05-2015 08:31 AM
