How to lubricate the steering bushings/joints/etc
Old Jul 20, 2007 | 09:36 PM
chisss's Avatar
chisss
Hello I have a problem where my steering column creaks a lot when I turn it. it makes like a loud crack. It is getting worse but since I have 58K miles it is not under warranty.
Is there a way that I can do the lubrication myself? does anyone know how to?
Old Jul 21, 2007 | 08:55 PM
joey1320's Avatar
joey1320
first of all where is the noise coming from exactly? can you hear it inside and outside the car?
Old Jul 21, 2007 | 09:56 PM
Grassroots Garage's Avatar
Grassroots Garage
The early cars (up to 12/02 production) had this problem. Replacing the upper steering column assembly with the updated replacement will fix this. It seems that the upper shaft would get bent slightly and damage the bearing. I have not had any luck in repairing these.
--Dan
Old Jul 22, 2007 | 02:49 AM
YakiMini's Avatar
YakiMini
Move the Steering Wheel around a couple of times, set it, and then repeat again. (the info was relayed to me a while back and it worked fairly well!) Otherwise, the dealership wanted around $850 to replace the column.
Good Luck!
Old Jul 22, 2007 | 03:57 AM
lhoboy's Avatar
lhoboy
I had the same sound at 37,000 miles. Real loud and annoying. The rack and pinion assembly had a loose bolt. Dealer tightened it, no problem since.
Old Jul 22, 2007 | 10:21 AM
chisss's Avatar
chisss
the sound is outside and you can definetly hear it.. you can also feel it in the steering wheel.
What do you mean by this? I mopve the steering wheel every time..lol
Old Jul 22, 2007 | 10:45 AM
lhoboy's Avatar
lhoboy
It's definitely not the steering column then. I'm guessing it's the loose bolt I was talking about.
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
jeri534
Nov 6, 2015 01:40 PM
torpeau
Oct 8, 2015 11:10 AM
Samhillrocks
Sep 29, 2015 12:55 PM
