Suspension Knock. *Help*
Old Jun 13, 2007 | 05:49 PM
MINIGT50's Avatar
MINIGT50
I am experiencing a distinct knock coming from the front end of my 04 MCS. It happens whenever there is an offset bump, when the front suspension is doing different thing on the left vs. right. For example, when I go over a speed bump slowly but straight, it does nothing. If I go over the speed bump slightly offset where one front wheel hits it before another, the knock is there. It is noticable on bumpy roads, mainly audible when going slowly.
I think this may be an anti-roll-bar issue, but not sure. The dealer tried to diagnose it, but nothing they did fixed it. Anyone else have this issue, and if so what was the cause and the fix?
Old Jun 13, 2007 | 09:40 PM
Jazz042's Avatar
Jazz042
I had a similar issue on my '05 though I don't know if this is the same cause for your knock. I had loose bolts on my front right control arm. Take off the wheel and take a look. Be sure to check to bolts you can see plainly and the bolts on the bottom of the arm as they hide extremely well. Hope this helps!
Old Jun 14, 2007 | 09:05 AM
minimusprime's Avatar
minimusprime
check the ball joints for cracks/shattering
check the sway bar end links for cracks/shattering
Check the stearing/suspension knuckles
check the rubber mounts on top of the struts that you can see through the strut tower holes
that's all i can think of for now.
Old Jun 16, 2007 | 02:13 AM
MINIGT50's Avatar
MINIGT50
Thanks everyone for your help!
Old Jun 18, 2007 | 06:12 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Shock nock in the rear
Hey everyone, not meaning to hijack this thread, but... I have this same problem only mine is the rear right side of the car. Anyone know what it is?
Thanks.
Old Jun 18, 2007 | 06:23 AM
2Miniacs's Avatar
2Miniacs
This could be a symptom of worn control arm bushings, which are a common wear item on the E46 BMW's.....which are the same design as our MINI's.
Old Jun 18, 2007 | 12:44 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
HMMM... That I will have to check on thanks alot.
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Minibeagle
Aug 13, 2015 10:00 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
