Motormount again!!
Old Jul 9, 2007 | 09:47 AM
newunit's Avatar
newunit
Motormount again!!
I have a 05 MC and it has had no fewer than two motor mounts replaced. This weekend I noticed a small leak under the car. After checking the color and doing a quick taste test it appeared to be coolant. After checking the level it was okay. I jacked up the car and saw an oily substance on the lower motor mount. It looks like I will be replacing the third motor mount in two years . Has anyone beefed up their motor mounts with IE bushings?? I already have a TSW damper and I assume the mount was already experiencing fatigue before I put the engine damper on. Any thoughts would be appreciated.
Old Jul 10, 2007 | 08:32 PM
PenelopeG3's Avatar
PenelopeG3
I've been contemplating the urethane IE motor mount bushings also. Probably don't need the engine damper with those.
Old Jul 11, 2007 | 12:33 PM
newunit's Avatar
newunit
Thanks for the input. I see you are in SD. I am in OC.
AlexQS
Apr 21, 2013 06:17 PM
astrochex
May 2, 2011 08:54 AM
brigadoonb
Apr 6, 2008 12:38 AM
cpayne
14
Jul 25, 2007 10:22 AM
